Question about Panasonic KX-FL511 Plain Paper Laser Fax
Vertical lines on the entire page
Is there any way of cleaning the drum unit on this fax machine? I was told that the only solution is to buy a new drum unit...the problem is that they retail for more than what I paid for the original machine.
I can see dry toner right on the green roller. Is there any way of flushing it out and then start over with a new toner cartridge?
Any suggestions are very much appreciated!
Regards,
Frank
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Sorry, what actually happens is that there is a drum blade, it fails which lets toner go by instead of scrapping it off the drum, which results in rings around the drum and lines on tjhe copies
so yes you do have to buy one.
good luck
Posted on Dec 07, 2007
I have a toshiba 166 copier,in my print page i have several vertical ghost black line,every thing i do but that's not removed,i cleaned charger wire,and drum,blade,but i don't whats the problem?
that is caused by a drum or Main Charge Grid ,fuser.. check the fuser unit and verify that there are no visible wear marks on the Teflon roller... if not it would be comming from the drum unit (photo receptor) or Main Charge Grid needs replacing? cleaning
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 03, 2014 | Toshiba Estudio 166 Digital Copier Machine
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Vertical lines when it prints, etc.
Vertical print problems are going to mean a drum replacement on that model. You can try to pull out the drum unit and carefully, with a lint free cloth, try spinning the drum and cleaning it off, but more than likely the coating on the drum has worn off where the vertical defect is. New part # dr-250 for that machine model..
Feb 28, 2009 | Brother MFC 6800 All-In-One Laser Printer
My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
White vertical line on received faxes
hi,
The upper glass is under the drum unit.
- Remove Toner and Drum Unit and you will see the glass. Try to clean it.
Bye.
Dec 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Black lines on received faxes
look for a corona wire, close to the drum
  2. Return the tab and snap it into the home position.
zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Jul 18, 2008 | Brother IntelliFAX 4100 Laser Fax
    Drum? glass? on faxphone?
    try this take out drum( toner) clean machine see if there is a thin strip of glass on bottom inside the machine. make sure it is clean, this will give you black lines if dirty.
    here is the manualit can guide you better, look for the troubleshooting and maintenance section
    http://www.retrevo.com/s/canon+b640++manual?rt=tr&p=http%3A%2F%2Fwww.usa.canon.com%2Fcpr%2Fpdf%2FManuals%2Fb640_ug.pdf
    good luck
    Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
    Even vertical lines on fax/copy
    TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
    Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
    Panasonic KX-FL511 Plain Paper Laser Fax Logo
    71 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    jasbo
    jasbo
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
