Question about Acer Aspire 5630 Notebook
Aspire 5360 hiya ive had my laptop for a year but recently it has started turning itself off and then i have to wait for 2 minutes before i can turn it on. When i do it does a FAT32 scan?? Its been happening more and more frequently recently, ANy ideas? Thx Fraser
  • 1 more comment
  • Rayalaseema Dec 28, 2008
    I also have the same problem and also i am unable to use my yahoo messenger and some other facilities which i used while i bought the laptop for the first time. now its been one year my laptop is becoming a SCRAP.
    Also the system speed had slowed down
  • pete3220 Dec 28, 2008
    I have the same problem. Purchased it Aug 2007. Just after the 12 month purchase date it started to turn off when in use, usually when a game is running. Now it also turns off when simply connected to the internet. I dont really rate these lap tops and wouldnt purchase another ACER.
    On checking other websites they state that there may be dust inside the system, causing it to overheat, therefore it would require internal cleaning.
  • awday75 Dec 28, 2008
    i have just purchashed a acer 5300 which turns its self off after approx ten mins running time the battery lights continues to flash orange not green as you would expect could anybody help
Mine was turning itself off with no warning quiet frequently.
unscrewed the panels on the underside so i could get to the fan, pulled the dust balls out, and it's been right as rain ever since.
was really easy to pull apart and put back together and i didn't even have to expose any circuit boards,so i figr it's a pretty safe bet too.
ob just make sure it's not plugged in and the battery's out.
Posted on Apr 23, 2009
  • 36 Answers
The 2 most likely causes are: it is getting too hot, or the power supply is failing. For the first, you can make sure that it is getting good airflow around it, and especially underneath the laptop. Purchasing a Laptop Cooling Pad should help.
If it is a bad power supply, you will need to seek warranty repair, or take it to a laptop repair shop, to get the power supply replaced.
Posted on Dec 06, 2007
  • Rob Jacobson Dec 06, 2007
    The FAT32 scan of the disk is quite normal, because it turned off without properly shutting down the operating system.
I cant get a network signal on my phone its a samsung galaxy s 5360 how do i fix this ive tried sim and all usual t
turn off WIFI; reset network settngs; make sure cellular data is turned on by going into Settings>network>mobile networks>mobile network>make sure this has a checkmark. call carrier and have them cancel the registration on your phone. call them from a different phone and have your Galaxy turned off .
Oct 19, 2012 | Samsung Y GALAXY S-5360
My computer starts then shuts off i havent used it for about 2 years ?
It could be overheating. Do you hear fans running when it's on? If not, the CPU Fan may not be working. Also the Thermal Paste around the CPU and Heat Sink may have dried up or is not thick enough to keep the laptop cool, so it shuts down. You will have to take the laptop apart to fix either of the two things mentioned so far.
You might have a virus that is causing you to shut down. Try booting the system in Safe Mode and see if it stays on. Turn the laptop off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE option. Select Safe Mode and let it boot up. Most times the virus can't operate in Safe Mode because it needs the Internet Connection. If it stays on you will need to run your virus scan.
Mar 26, 2012 | Acer Aspire 3690 Notebook
When loading my laptop it's taking at least 20 minutes to start the internet. The laptop is only 2 years old and it has only recently started to do this.
When you eventually get on the internet, download and asc-setup. Run the registry error utility.
That will help.
Feb 18, 2011 | Acer Aspire 5100 Notebook
Battery indicator keeps fluctuating to 4hrs to 6hrs back to 4hrs then 8hrs every 5 mins or so i have acer A0532H with windows 7
first of all let me ask how old is the battery, if it`s new-discharge the battery until pc shuts down itself because of low battery, remove the battery , unplug AC charger from laptop, wait for 5 minutes, then hold power button for 5 full seconds, wait another 5 minutes, then put battery and ac charger on , don`t turn on laptop yet, wait until battery indicator shows that battery fully charged, then remove AC charger, and turn on laptop. P.S. you can try this on old battery too, but usually worthless, because old batteries are not recognizable by system currectly ..
Mar 10, 2010 | Acer Aspire One AOA150-1457 Notebook
When I turn on my Acer it starts and then turns
your keyboard is stuck try to tap on the 9 key it free it if that doesn't work you will have to pry it up very gently as not to pop it off
Nov 23, 2009 | Acer AOA150-1690 Aspire Notebook
My Acer One Aspire is stuck in hibernate. After it updated itself and said it was preparing to shut down, it was stuck in the preparing for shut down mode for hours. When I let the battery run down to turn...
This solution may sound stupid, but it is affective. Try to press really long time (about 1-2 minutes) on the power button of the laptop. wait for it to shut down completely. Then turn it on to see what happens.
What may have caused this is an update of any sort.
Nov 11, 2009 | Acer Aspire One PC Notebook
My netbook deactivates by itself minutes after fully booting up
this is due to static charge accumlated on the motherboard
Just press and hold power button for 45 seconds and release
do not charge the notebook while doing the bove(No power scocket)
Apr 05, 2009 | Acer Aspire One PC Notebook
Brand New laptop, won't start
Try taking the battery out before you turn it on. Have seen completely a dead dead battery keeping a laptop from starting up. Does the hard drive activity light flickering? If it is you can try holding down the Function button (FN) and there should be another button to hit to switch between LCD\CRT.
Mar 01, 2009 | Acer Aspire 5520-5908 Notebook
Power problem
I think it is not having problem with the software or the windows.
The main problem is you don't give the specification detail , for instance the memory module itself, what memory module do you use, does it have 2 memory module, if it has then it could be .. but if it doesn't do you recently upgrade your laptop? or the ac adapter, or the baterai itself.
Jun 24, 2008 | Acer TravelMate 2300 Notebook
Check to see if this happens when booting into safe mode.
Jun 05, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5630 Notebook Logo
678 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
