Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Does not accept admin as password
I cannot get my router to work.
I get the log in screen but does not accept the pasword.
What can I do?
Thanks
Rob
  • 259 Answers
Someone may have logged into your unit and changed the admin password. you can reset the unit by reseting to factory default settings.
Reset the router to its factory default settings and restore the other devices on your network to their default settings. You may do this by pressing the Reset button on the back of the unit. You will lose the current configuration settings.
Hold button for a few seconds.
Posted on Dec 07, 2007
  • Rafael Ortiz
    Rafael Ortiz Dec 07, 2007
    You sould be able to log into the unit of the reset with the admin account. Leave the password field blank
Live massenger
Posted on Jul 27, 2008
  • 27 Answers
Try having admin as the user and leave the password field empty. If that doesn't work then you will have to press the reset button on the back for 10 seconds. Everything will be reset, including your settings. That will also probably solve whatever is keeping your router from working well.
Posted on Jan 05, 2008
    Problem Solver:
  • 11 Answers
NOT ENOUGH INFORMATION.
"NOTE THIS"
YOU HAVE TO MAKE SURE THAT YOUR PROVIDER, DSL OR CABLE MODEM IS ON.
AND MAKE SURE ALL THE PROPER LIGHTS ARE ON.
DISCONNECT ALL AND RE CONNECT.
THEN TRY TO LOGIN.
YOU HAVE TO MAKE SURE THAT WHEN YOU TYPE YOUR PASSWORD CAPS ARE NOT ON IF YOU DIDNT SET YOUR PASSWORD WITH CAPITAL LETTERS.
HIT ME BACK WITH A REPLY ON THE STATUS AFTER YOU HAVE DONE THIS.
Posted on Dec 06, 2007
Change pasword and name admin
its pretty easy, log in and go to admin tab
if you don't know the username and password to start the hold in the reset buttons until all the lights flash at the same time a couple times and then let go.
now the username and password are admin and password and you have lost all settings that were in your router such as wireless SSID and password, port forwarding, and static ip's... should have mentioned that 1st ;}~
Sep 16, 2013 | NetGear N150 RANGEMAX 150 Wireless Router
NETGEAR wnr2000v3 router not accepting default password after reset
I have the same problem but can not even log in for the 1st time. admin and password do NOT work. And when I checked the ip address w/ the ipconfig /all aomand in a command prompt, I found that it has ip address 192.168.5.1 So when I tried to log in to that page, it prompted me for a user & password. Again, admin and password did NOT work. Also, tried 1234 for the pasword with no luck. Is this box defective??
May 04, 2012 | NetGear N300 Wireless Router
Factory pasword for wrt120n
Are you speaking about default password of Linksys router?
The default password is admin, leave the user name blank.
If the default password is not accepted then you can try to reset the router.
Remember if you reset the router, it will come back to factory default settings and you will need to reconfigure it.
Dec 07, 2011 | Linksys WRT120N Router
Pls forgot ma password can't get in my laptop
DO ONE THING
1.GOTO SAFE MODE...HOW?? PRESS F8 WHILE THE COMPUTER IS RESTARTING JUST BEFORE THE WINDOWS SCREEN APPEARS
2.CHOOSE ADMIN LOG IN
3.THEN GOTO CONTROL PANEL
4.THEN GOTO USER ACCOUNTS
5.THEN CLICK ON REMOVE PASSWORD..HOW?? THERE YOU WILL SEE AN OPTION SHOWING USER ACCOUNT AND ADMIN ACCOUNT BELOW ...JUST LOOK OUT FOR THE REMOVE PASSWORD OPTION THERE..
Thanks and Regards
Trinoj
Pls vote for me..if u like my solution
Aug 05, 2011 | Computers & Internet
Wnrb834b Setting security password
The default password for this router is password
User name : admin
Pasword: password
With the above username and password you would be able to log in to the router's home page (default Gateway- GUI)
Then incase you require you can change the router password or the wireless security key.
# If the above password is not working it may be possible that u had already set up/ changed the password hence you will have to Hard reset the router for this to work.
# How to Hard Reset ? = Insert a paper clip or pen in the reset hole located near the ports of the router for 30-30 second while the router is powered on
Hope this helps
Thanks.
Please Rate my answer/ or if you require any further clarification please comment
Jul 03, 2011 | NetGear DG834G Router
Want to change user name and pass word
You can do so by opening the GUI page of the router:
First connect it to the computer through a Ethernet wire and then check the default gateway (go to command prompt and type ipconfig)
put in the default gateway address in the internet explorer address bar
Log in to GUI..the default username and password is following
Username: admin
Password: admin
or
Username: admin
Password: password
Log in and change the username and pasword...you would also be able to change the wireless password (WEP key) from same
Sep 25, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Can't configure router
If you reset the router to factory default and use admin and no password you should get it or sometimes admin and admin for password as well or check the manufacture website to find out what is the default user name and password for that model
Apr 27, 2009 | Computers & Internet
Recover new password (paraphrase)
user name is admin and the password is password or blank or admin or 123456 or 1234 this all combitation is there try it
Mar 28, 2009 | ASUS WL-530g Router
Problem
point your browser to -> 192.168.10.1
default user and pass is:
user: guest
pass: guest
(i have tried posting this solution 5 times now and it never shows up!)
Dec 01, 2008 | Zonet ZSR0104CP (zsr0104cp) Router
How to..?
You will need access to the router. Press and hold the “Reset” button for at least 10 seconds, then release it. The lights on the Router will momentarily flash. When the Power/Ready light becomes solid again, the router has been reset. To access the routers web page, in your browser, type 192.168.2.1, in the login screen, leave the password blank and click the “Submit” button to log in.
Once you have logged in, be sure to go to “System Settings” page where you can enter a new administrator password.
Good Luck!
Aug 09, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
348 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
