Question about Sony Handycam CCD-TRV308 Camcorder
Tape keeps ejecting itself
I have a Sony Handycam CCD-TRV308. When I put a tape in to try to watch it, it ejects it immediately after the door closes. What could be causing this?
  • mswanson502 Dec 06, 2007
    I have a Sony Hi8 MP and a Fujifilm tape that do the same thing.
  • mswanson502 Jan 16, 2008
    Is it worth trying to have fixed?
Wow it worked ! After a couple of good swats on the tape side of the unit it appears to be working great. Thanks for the advice.
Posted on May 16, 2008
    President:
  • 4,402 Answers
Tape sensor bad or bad tape
Posted on Jan 16, 2008
  • Cary Farah
    Cary Farah Jan 16, 2008
    try this
    Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
    if that doesn't work try
    Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
TAPE WILL NOT EJECT BLEEPING AND FLASHING C;32;11
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Cheers
Oct 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Camera won't accept tape
tape senors is bad or have a bad tape
Jul 31, 2007 | Sony Handycam CCD-TRV308 Camcorder
Sony Handycam CCD-TRV308 Camcorder Logo
1,209 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
