Nikon D40x Digital Camera Logo
Posted on Dec 06, 2007
D40X raw format reading error
I started shooting raw images with my Nikon D40X. For a while it was working with raw software under Linux just fine (I use UFRaw), and I have a few viewers that can view raw pictures. Then suddenly all of my viewers and UFRaw stopped recognizing new pictures taken with the camera, my Ubuntu file viewer recognizes the files as text in file properties (while the older files are correctly recognized as Nikon images). Finally, neither Photoshop Camera Raw nor the DNG converter version, that supposedly support this model, recognize these files.
  • Anonymous Mar 13, 2008
    yeah i have the same problem too. but for my windows the Photoshop CS3 does not even recognise the RAW format for the D40x
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 15, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
4031
Points
9
This does not seem to be a problem with the camera, but a problem with the computer software.
2answers
Convert NEF format to JPEG
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
What does raw+fine pictures mean?
The raw+fine setting indicates that your camera will take both raw (NEF) and high resolution JPEG pictures with every shot. You can change this to shoot just JPEG or just raw shots using your menu under the little camera icon. Click on image quality and it will give you multiple settings so you can choose only raw or only JPEG. You have three JPEG settings: fine, normal or basic.
I always shoot raw+fine which I think may be the default setting. I use the jpeg pictures for simple and quick editing and I use raw for detailed editing. JPEG pictures deteriorate quickly during editing while raw pictures can handle extensive editing without significant deterioration.
When you shoot raw+fine, it means the camera is actually storing two pictures of the same shot, one in each of the two formats. When you view the pictures in Windows, you can tell the difference between the raw shots and the jpeg shots because the raw shots have a broad black bar across the top and bottom of the picture while the jpeg shots fill the screen.
1helpful
A list and defintion of the file types raw b, raw, fine, norm and basic
The D3000 can store still images in two different formats. JPEG is a standard format, recognized by just about every image viewer and image manipulation program in the world. RAW is actually NEF (Nikon Electronic Format), a Nikon-proprietary format which incorporates almost all of the data captured by the sensor, without the processing of JPEG. JPEG files have the color balance, sharpening, contrast, and all the other camera settings done on the picture. With RAW files, you can change any or all of them and produce new JPEGs. In this respect the RAW file is similar to the original negative you get from processed film, while the JPEG file is like the final print. RAW files need special software for viewing and editing.
All JPEG files are compressed to save space. FINE, NORM, and BASIC represent different levels of compression. FINE does the least compression and takes up the most space, BASIC does the most compression and takes up the least space. Compression always loses some quality, so in general the less the compression the better the quality.
RAW+B simply stores each of your pictures as a RAW file and a BASIC JPEG file.
Having said all that, you should use only RAW or FINE settings. You didn't buy a SLR only to throw away picture quality, did you?
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    How do I shoot images in JPEG format inste4ad of Nikon format?
    Press the image quality button repeatedly to cycle through the following values: NORMAL, FINE, HI, RAW, and BASIC. The image quality button is the topmost button in the cluster of buttons just above the speaker on the left side of the camera, marked with a sort of fan-like icon spreading from left to right.
    1helpful
    How to overlay picture in D40x camera
    Overlaying pictures, like almost all photo manipulations, is better done on a computer using "real" software rather than on a camera. You get much more control on a computer. However, the D40 does have a wide repertoire of photo manipulation capabilities.
    In order to overlay images, you must be shooting in RAW (or RAW+JPEG). Select Image Overlay from the Retouch menu. A preview dialog will be displayed with Image 1 highlighted. Press OK to get a photo selection dialog. Use left/right to highlight the first picture in the overlay. (You can press and hold the Zoom button to see the selected photo fullscreen.) Press OK to select the image. Optimize exposure for the image by pressing up/down. Press left/right to highlight Image 2. Select the second image the same way. Press left/right to highlight the Preview column. Overlay will show you the result, allowing you to go back and change things if you wish. Save will save the overlaid photo.
    The shadow in the lower portion of your camera is probably caused by the lens hood. The solution is simple: remove the lens hood whenever you're using the built-in flash.
    1helpful
    Can D40X do double exposure on a single frame
    The D40x does not have this facility.
    All you can do is to combine two exposures in your processing software; it's best controlled by combining two or more RAW images.
    1helpful
    Camera RAW and PhotoShop CS3
    To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
    A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
    Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
    The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
    The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
    See also:
    Adobe - tutorial : Lights, camera, action!
    Batch Processing Camera RAW images in Photoshop CS
    Creating a Droplet : Adobe Photoshop Tutorial
    1helpful
    I have the nikon D40x and am shooting in raw need software to convert what do you suggest
    Nikon ViewNX: free at http://support.nikontech.com/app/answers/detail/a_id/61
    Nikon CaptureNX2: trial version at http://support.nikontech.com/app/answers/detail/a_id/61
    Adobe Camera Raw: included with Adobe Photoshop
    D40x and TIFF images
    Okay, the D40X does not give a TIFF option. If you have the manual for it, I found the settings options for image size and quality on page 42 of the download version from NikonUSA
    You can shoot Raw/NEF
    Top Nikon Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
