Question about HP LaserJet 1300 Printer
Hp 1300 with added papaer feed tray q2485a
Tray has stopped feeding. reverts to main tray for feed after clicking for 5 secs or so.
  • peterpumpkin Dec 06, 2007
    forgot to mention that it is not the lower tray, the q2485a. bought a new one, and that isn't it.
  • 89 Answers
I am a little unclear as to where the problem is but you should check the pick up rollers and make sure they are not smooth, there needs to be some grip to them. If that does not seem to be the problem then the gears may be out of alignment.
Posted on Jan 22, 2008
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Hp q2485a
When you print a document you can go to printer properties and select Paper Source then Tray 1 or Tray 2 before you print.
My HP printer I have white paper in Tray 1 and recycled paper in Tray 2.
Feb 25, 2012 | HP LaserJet 1300 Printer
HP Officejet Pro 8500 Wireless All-In-One InkJet Printer Paper feed will not drop down every time, and is making a grinding noise. Is replacing that piece available?
Hi. You leave a question mark?
I don't understsand what you mean by Papaer feed will not "DROP DOWN"?
I to have the same printer, the paper feeds from the tray (s) from below.
A little more info please?
The grinding in the system trying to feed through the paper.
Just a thought, turn the printer round find the release levers and check the internals for paper jam.
Mar 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Hp laser 1320 manval tray paper not feeding proprly contynue
you need to take ou the tray and look at the bottom you should see the feeder that pull the papaer make sure its not loss and try to clean the rubber wheen sometimes its dirty if not maybe the clutch is broken
i hope it will help
Aug 21, 2010 | HP LaserJet 1320 Printer
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
My printer says i am out of paper but i am not
Check if the software you are printing from is set to feed from the manual feed (top back) instead of the main paper tray. You can put a sheet of paper in at the top to see if it takes that instead of the main tray, If so, change the settings in the Printer properties to feed from the main tray first.
Aug 04, 2009 | HP LaserJet 1100 Printer
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
Load Noises
If the HP LaserJet series printer is experiencing a grinding or odd noise when printing or on power-up, open the printer and remove the print cartridge. Close the printer door.
If the noise does not recur with the print cartridge removed, replace the print cartridge.
If the noise persists, this may indicate a hardware failure. If possible, isolate and identify the location of the noise and contact a local HP sales and service ofice at the number noted in the product User's Guide . A list of phone numbers can be found at
http://www.hp.com/support .
Feb 15, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1300 Printer Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
