Question about Philips 60PP9753 60" Rear Projection Television
Hitachi 46 It has a double image on the screen. Made ajustments and no luck.
  • Philips Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 15, 2009
    Problem Solver:
  • 5 Answers
You have a convergence problem. Probably the convergence IC's. Usually they are located on a large silver finned heat sink. There are usually two or three and they start with STK in the number. Common #'s are stk392-010 or STK4****. They need to be replaced.
Posted on Dec 06, 2007
We have a 46" Hitachi TV that suddenly after the cable man hooked up a new receiver box has gone funky! The top left of the screen is wavy down about a third of the screen and the wording is...
What you just described is a convergence issue, Now most tv's have a auto focus button on them or the remote try giving that a push (if your tv has it) I cannot go by the model above because fixya has categorization errors or people select the wrong tv.
But this is a convergence issue if the focus button does not take care of it your going to need repair.
thanks for using fixya.com , please do leave positive feedback or ratings, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 26, 2010 | Hitachi 46F500 46" Rear Projection...
There is a wave in the picture only in the upper left hand 1/4 or the screen. The rest of the screen is sharp. You get the colors separated and thus double image.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 23, 2010 | Hitachi 46F500 46" Rear Projection...
Screen has a double image. looks like the green
Convergence is the problem. I just fixed my set myself with a kit from TvRepairKits.com
Nov 16, 2009 | Hitachi 50UX58B 50" Rear Projection...
The picture on my Mitsubishi rear projection big screen has pink and green lines going around all of the images
you will need to ajust the convergence of your tv. there should be a "test" swich/feature that brings up a grid on the screen. ajust the horizontal and vertical of each of the colors until the lines become white. you will need to be more specific on which model you have if you need more detailed instructions. it should cost less than $75 to get a tecnician to come over to fix this.
Aug 08, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
The image of my 53sbx10b are double after few minute
Replace convergence ics. Hitachi has a ki for this consisting of STK-395-110 ic and some resistors.
Apr 13, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Getting double images on screen like outlines on images
Your TV has a failure of its convergence output ICs and perhaps some of the convergence circuit's other associated parts. The part numbers for the ICs are on the IC face. They can be purchased thru Hitachi or online at MCM Electronics.
Feb 10, 2009 | Hitachi 51F510 51" Rear Projection...
Tv looks green and bowed, also has double image
your tv is having a convergence problem, nothing you can do aloneyou wll need to call a tech, there must be 2 bad ic and some resistor burnt
Jul 30, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Double images on top third of sceen
Faulty alignment mechansim or colour wheel. Expense unknown.
Oct 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FXD20B Spots with colour
take your tv to a tech and have them check your tv the color module could be the problem or the the convergence module.good luck.
Apr 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Philips 60PP9753 60" Rear Projection Television Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
