Question about Canon imageCLASS D780 All-In-One Laser Printer
Paper jam My Canon imageclass D780 has paper jammed, i check everywhere but could not locate the jam, please help!!
  • David Met May 16, 2008
    paper james just before it exits the copier on bottom How can I get to bottom of copier to remove jamed paper
  • jamicky Dec 30, 2008
    it says that there is a recorded paper jam in left platen....
Unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Posted on Jan 15, 2008
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Tip
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After clearing the paper in all access doors (both front and back), the printer still gives the paper jam error. Also, if you have tried restarting the printer several times to no avail and the red light keeps blinking, here is the fix to what is most probably been causing the paper jam problem of Canon ImageClass MF3240.
1. Turn off the printer and pull out all plugs and power cord that is attached to your printer.
2. Remove the paper tray at the bottom and let the printer lie at its back so that you can see underneath.
3. Get a flashlight and look closely for the sensor located underneath the printer. The sensor is located in a small square hole, just above the small black plastic "lever" (looks like a small hockey paddle) on the left side of the gray rubber roller. Move the lever so that you can freely look closer on the hole.
4. Notice because there could be a tiny paper shred stuck inside and this causes the sensor to detect a paper jam.
5. Get a small tweezer to remove that paper out.
6. Next, let the printer stand normally and return the tray back.
7. Re-plug all cables and start your printer. That's it!
on Jan 07, 2010 | Office Equipment & Supplies
Paper is all wrinkled and jammed up just before exit...can't pull it out and no access. Different than a "regular" ppr jam
In most cases, it's easier to pull the jammed paper if you turn the printer OFF and the pull the paper VERY SLOWLY
Apr 02, 2010 | Canon imageCLASS D780 All-In-One Laser...
It says there ia a paper jam and there is not one. We have looked for one everywhere and can't find a paper jam
open all of the paper casettes.make sure no jam there. then with the cassettes open open and close all of the covers. it is possible you have a bad sensor saying a false jam
Jan 25, 2010 | Canon ImageClass MF6540 Copier
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Paper Jams
Turn off the printer and checked for any obstructions or foreign objects from where you load the paper and where the paper comes out.
Jun 13, 2008 | Canon imageCLASS D780 All-In-One Laser...
Copier will not allow to use
E codes are usually paper jams take out paper drawer and look for jammed paper if you dont see any unplug copier from wall and plug copier back in somtimes this wil force paper trapped in copier out as it powers up.
Jan 15, 2008 | Canon imageCLASS D780 All-In-One Laser...
Canon imageclass printer 5550
I have crazy feeding/paper jam problems with my MF5650.
Oct 06, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS D780 All-In-One Laser Printer Logo
301 people viewed this question
old marine
old marine
