Question about Car Audio & Video
Amp problem my amp blows fuses. i have checked the wiring up and down and cant find any shorts. but about 2 weeks ago (when this began) my cd player was not working so i had to press the RESET button to get it back online. i havent changed any settings or components save a new car battery, but i got that after i started having problems. when i put a new fuse in and turn the key, the amp power light comes on red, turns green, and then POP! blown fuse.
  • chop904 Apr 14, 2008
    i have two esc 12" subs they aren't the best but they gets the jobs done. when the bass drops, the sound fades away it sounds like the amp isn't getting enough power. i have two 30 fuses in it but i think they too small. what size fuse should i get?
I had the same problem i took the amp apart and found a screw that had worked its way loose i took it out and now the amp works properly i think it was just jammed in some kind of power source. just give it a look and see hope this helps..
Posted on Feb 23, 2009
  • 66 Answers
Are you handy with a volt meter, I would first check for shorts, what amperage fuse are you using? Do you know what amperage is reccomended for it? manual?
Posted on Dec 06, 2007
Number 21 fuse keeps blowing vw tiguan 2009
check the bulb it may be shorted out try new bulb and see if fuse stops poping if it does not the you have a shorted wire
Aug 25, 2017 | Cars & Trucks
My alpine CDE-7870 Cd player stopped working and i cant find out what is the matter with it
The power line has a blown fuse. Check under the dash or wherever the fuse box is that controls the stereo. Also, check the inline power wire cause they have those little cylindrical fuses that blow. Also, make sure you got a good ground and check for shorts.
No not your shorts. Check for shorts in the wiring.
Feb 12, 2010 | Alpine CDE-7870 CD Player
I have a 97' f150 4.2 eng 2 wheel drive pickup elect. problem
A fuse blown is a short, and a short is a ahort.
The fuse is the ecm so unplug the ecm and see what happens. If the fuse holds with theecm unplugged, then it is your ecm that needs relacement. If it still blows, The short is in the wiring.go to the parts store and pick up and automatic circuit breaker. It plugs in where the bad fuse goes. It will trip and reset itself automaticallly like a flasher until you have located the short. trick, Start with a breaker of amp. examole; if you took out a 20 amp, put in a 10 amp so the breaker trips faster, On and off quicker so you don't have to wait between ressets. If you want to trace the short by the wiring, put a 25 amp or with great caution a 30 amp. That is the limit. The wire will get warm on the 25 and even warmer on the 30. Pay attention that the wire does not get hot. Hopefully yhe 25 will get the wire warm enough for you to follow. Good Luck, Ned. This method is dangerous if you don't pay very close attention using the high amp breaker. There is a risk of fire if the circuit cannot handle 30 amps. In fact, only yuse the 30 amp breaker if the 25 breaks and resets too fast. Good Luck_Ned_
Oct 04, 2009 | 1997 Ford F150 Regular Cab
The fuse on the control circuit on the inside unit keeps tripping One side of the fuse goes to the thermostat the other side goes to the control board the fuse blew about a week ago let the unit sit for a...
Its hard to say without being there but here are somethings to check. Outside check the thermastat wire onthe condensing unit. I have this problem a lot down on the gulf coast. The wind blows and cause the Tsat wire to rub against the unt and it shorts the fuse. Will run for a while till a storm or winds come up check this first. Next could be bad contactor or relay but most likely the tsat wire. Check back and let me know please. Russ
Jul 18, 2009 | Heating & Cooling
Starter/Fuel Pump fuse, or the Relay Fuse blow
the fuel pump comes on when you turn the key on the starter comes on when you turn all the way to start so i would think the short is in the fuel pump if it blows by just turning the key on
Jul 17, 2009 | 2002 Chrysler Sebring
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
LG Dyer blows 30amp fuse frequently
Hello davidkado,
There is a high probability that when you replaced your fuse box to circuit breakers that the wiring at the fuse box was retightened. If your dryer had been operating Ok for the better part of a year and then you started to blow fuses on a regular basis.. chances are the wiring coming from the fuse box tap was becoming loose from thermal expansion and contraction and that by changing to a breaker system.. your wiring was cut and reterminated to fit the breaker tap. I suspect you won't be having any additional problems...
Regards,
Rick
Jan 02, 2009 | LG DLE2514 Electric Dryer
My amp wont turn on
The reason it used to cut-off at 60% volume as you said before,
Is probably due to the "protection circuit mode" being tripped.
You can try resetting it by turning off your CD player ,removing the Batt( + ) and Gnd ( - ) terminals from the amp for a short period. Reconnect them Allow the amp to receive power but not switch on (keep cd player/remote power source off)
If you dont know how to wire the CD player to control the amps power status , the easiest way is to connect the 'power antenna' or similar low voltage throughput wire from the head-unit to the amp's Remote terminal.
My old amp did the same thing ,and would need to be powered off/on before resuming sound output, sometimes I had lots of trouble with the protect mode staying on , even with little or no sound output from headunit.
Jul 14, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Factory radio keeps blowing fuses.
you should bypass the factory cd player. I installed a panasonic cd player in a 1994 gs 300 and it was hell. there are alot of wires that have nothing to do with the radio i believe one or some of those wires may be whats causing your problem try this solution if that doesnt work you may have a serious electrical problem
Mar 26, 2008 | Car Audio & Video
Car Audio & Video Logo
225 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
