Question about Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin Oil Radiato Heater
Defective plug Honeywell HZ 680C
I have a Honeywell oil heater and when I plugged the unit into the wall, smoke and flames started coming out. It's not the wall socket because I checked the heater in other outlets and it did the same thing. Very dangerous. Good thing it happened while I was home.
Can the plug/cord be replaced? Is there a recall on these units?
- Daryl
  • 625 Answers
Just change the plug - get it at a hardware store. if your cord is flat, the center conductor is earth ground, green screw. the ribbed conductor is the neutral (white) and the ribbed conductor is the hot (black)
Posted on Dec 06, 2007
My Honeywell HZ-717 won't turn on. Suggestions?
  1. If the Socket where the heater has been plugged in is receiving power, the Fuse in the Plug may have blown. Check that.
  2. Check for loose cabling contact.
  3. Since it is new, it must be under warranty, call the Service people from Honeywell first.
Feb 13, 2015 | Honeywell Electric Oil-Filled Convection...
If the sockets are hot (electrically, plug in something to confirm that sockets operation) and you are pushing the right button on the heater, then the unit is defective. There is no type of resettable sensor to my knowledge (not consumer accessible).
Nov 28, 2013 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell hz-710
Hello, welcome to Fixya!
Your unit is having a power fault because it is not switching on. The unit might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the unit is having a power fault.
When electric current comes from the power outlet into the unit, it goes straight into the power supply board which then circulates the current into the unit. So if the unit doesn't power on, the first thing is to make sure there is power entering into the unit.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store within your vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care.
Nov 05, 2012 | Honeywell HZ-710 Oil Filled Radiator...
Honeywell 709. tried to move to another room. forgot to turn off before pulling out plug. wont start. plug is ok, works for lights. wont turn on. what do i do ?
let sit overnight, most likely disturbed the internal t-stat.The oil has to settle again. And make sure power oi off before turning on.
Apr 01, 2011 | Honeywell HZ-709 Oil Filled Radiator...
My honeywell hz 709 heater tipped over slightly and now it will not come on. How do I fix this?
Hello, Usually unplugging the unit and letting tho oil settle for about an hour will reset the unit. Hope this works for you. Please reply and let me know , so if need be I may assist you further. Thank You!
Feb 14, 2011 | Honeywell HZ-709 Oil Filled Radiator...
The main on/off switch is defective... Where can I purchase another one? Honeywell portable heater HZ-515
dear sir /madam
please find out heater unit company,s dealer at your area you can purchase that switch or you contact to your maintenance personnel for further action .i mean replace your defective switch.
hope answer the question
please vote
thank you!
Sep 05, 2010 | Honeywell HZ-515 Baseboard Heater
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
*All Heaters*-Where can I get parts for my heater? Answer: Unfortunately, we do not have any replacement parts available online for heaters. You can obtain parts by calling consumer relations at 800-332-1110. The only parts currently available are replacement wheels for oil filled heaters. If you are looking for any other parts, please call us or send an email to and let us know the model number of the heater, the length of time you have owned it for, and a detailed description of what is wrong with it.   Question: All Heaters-Can I use an extension cord with my heater? Answer: You should avoid the use of an extension cord as it may overheat. However, if you have to use an extension cord , be sure it is a polarized cord of 14 AWG minimum and rated no less than 1875 watts.
 I could find no recall on you product. They do not supply parts. I am sure you can match up the plug and cord at any good hardware or appliance parts store. Are you sure it is the cord?  The element could be shorted out.
DO you have an ohm, meter or small batter light tester to tes t the cord and eliments with?
Dec 06, 2007 | Honeywell HZ780 Oil Filled Radiator Heater
Heating & Cooling Logo
166 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
