FixYa.com
Tags:
GE Zoneline AZ25E12D3B Air Conditioner
Defective Thermostat?
posted by Shrinker on Dec 06, 2007
My zoneline 2100's thermostat spins freely -- no resistance to it. The cooling works but is not adjustable as to regulating the cooling temp. The heat does not turn on at all. Is this something I could repair/replace on my own? Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Dec 06, 2007
Helpful (85)
hotuna
Rank:Wiz Wiz
Rating: 85%, 203 votes
well this is a very subjective question. How mechanically adept are you. If you know where to find the replacement OEM part, then its a mater of taking the control panel apart and replacing the wires one at a time from the old thermostat to the new one. It will have a sensor probe that will need to be routed and attached to the coil somewhere. The same place as the old one. make sure the bulb (if it has one) is not damaged. This may go without saying, but make sure the power is off first.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Air Conditioners problems?
Air Conditioners
Hampton Bay fan AC 552
Hampton Bay fan AC 552 Replaced... Answer This...
Air Conditioners
I have a delonghi 300w
I have a delonghi 300w Hi-power... Answer This...
Air Conditioners
MATSUI MPA7KWR 7000BTU Portable...
matsui mpa7kwr 7000btu portable... Answer This...
Air Conditioners
I need to fit a
I need to fit a new cooling fan... Answer This...
Air Conditioners
my prima breadmakers trips the
my prima breadmakers trips the... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
