HP DeskJet 2000c InkJet Printer
Problem for HP DeskJet 2000c InkJet Printer
Color printing problems
By Growler72 on Dec 06, 2007
only in the last couple of days I have had problems printing color docs with my 2000C. If I print a solid green circle, as the paper comes out, the first part is green but the middle part is off color and more blue & faded and then the last part is green. I thought this would mean that I was out or low on yellow ink but I printed my ink levels and all colors are over half full. This problem also happens on different colors that wouldn't indicate a shortage of yellow. I love my printer but I can't justify spending hundreds of dollars for someone to look at it. Should I just go by a new one? If you have any idea about my problem, let me know. Thanks!
Solution #1
posted on Jul 02, 2008
Not Rated)
jglassm
Rank: Apprentice
Rating: 0%, 0 votes
I believe you are losing pressure on one or more of the ink pumps located beneath the cartridges. This is normally caused by breakage of "bongo" pad or pads and can have all sorts of strange results when it occurs. Check beneath all your ink cartridges. all 4 white pads should be upright and not flat against the base, and all 4 should feel about the same when pushed down for backward up spring pressure. Visit web site below for much more detailed information about this problem.
I repair HP2000C printers professionally and offer trade in allowance for your old printer.
www.glassmoyer.net/HP2000C
Was this helpful?
Yes
No
Solution #2
posted on Dec 06, 2007
Not Rated)
thumu
Rank: Guru
Rating: 86%, 130 votes
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to color issues with Printer . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
Well, these type of issues could happen due to below causes:
1. Due to refilled ink cartidges
2. Due to corrupted Printer software.
3. Color ink cartridges are low.
4. Color ink cartridge is with dust or if Color ink cartridge slot contacts ( Electrical Contacts ) are not clean.
5. if the ink cartridges are seated incorrectly...
To isolate and to resolve the issue, I recommend youu to try below solutions.
Solution 1 :
Please open below link in the new Internet Explorer. Copy and Paste the link at the address bar and then click GO. This will open a web page that titles as " HP Inkjet Cartridges and Media - Cleaning the Contacts "
Link :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?lc=en&cc=us&dlc=en&docname=c00058182
Once if you open web page, please perform the steps that are mentioned in web page to clean ink carttidges. I hope that this should resolve the issue. If the issue still persists then try next solution...
Solution 2 :
Please open below link in the new Internet Explorer. Copy and Paste the link at the address bar and then click GO. This will open a web page that titles as " HP Inkjet Cartridges - Resolving Banding, Missing Dots, or White Streaks in Printed Output "
Link :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&docname=bpa00226&lc=en&jumpid=reg_R1002_USEN
Once if you open web page, I suggest you to perform the steps that are mentioned under " Cleaning the cartridge electrical contacts " in the web page . I hope that this should resolve the issue. If the issue still persists then try next solution...
Solution 3:
Please try to Calibrate the ink cartridges of Printer, you can calibrate by using Printer properties under preferences and under Services Tab.
Please refer to user Manual for more instructions on this issue.
Solution 4:
try to uninstall and reinstall the Printer software.
This should resolve the issue for you.
If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
Was this helpful?
Yes
No
Popular Solutions for HP DeskJet 2000c InkJet
Questions and Unsolved Problems for HP DeskJet 2000c InkJet
Do you recommend HP DeskJet 2000c InkJet Printer?
Answer
Answer
Message says Wrong Cartridge , Display screen flashes with Wrong Cartridge or Insert Cartridge , but... (More)
Answer
no power after lightening storm. blew out dvr upstairs also. this is one of the 10 old combo... (More)
Answer
The ink thing of my Lexmark Z22 gets stuck and vibrates on the far right side of the printer. Is... (More)
Answer
pagepro 1350w paper jammed,I removed the page and still doesn't work. Think there may still be a... (More)
Answer
install software for portal optical drive connecting
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
