Step
Action
Yes
No
Install a scan tool.
Does the scan tool power up?
Does the scan tool communicate with the BCM?
Important: The engine may start during the following step. Turn OFF the engine as soon as you have observed the Crank power mode.
Does the Class 2 Power Mode parameter reading match the ignition switch position for all the selected positions?
Select the BCM display DTCs function on the scan tool.
Does the scan tool display any DTCs?
Does the scan tool display B1477 or B1478?
Go to Step 2
Go to Scan Tool Does Not Power Up in Data Link Communications
Go to Step 3
Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
Go to Step 4
Go to Power Mode Mismatch in Body Control System
Go to Step 5
Go to the Symptoms list in the appropriate service category
5
Go to Diagnostic Trouble Code (DTC) List
Go to Symptoms - Retained Accessory Power
The ability of the control modules to communicate through the serial data circuit.
The identification of any stored diagnostic trouble codes (DTCs) and their status.
The use of the Diagnostic System Check will identify the correct procedure for diagnosing the system and where the procedure is located.
Diagnostic System Check - Engine Electrical
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Lack of communication may be due to a partial malfunction of the class 2 serial data circuit or due to a total malfunction of the class 2 serial data circuit. The specified procedure will determine the particular condition.
The symptom list in Symptoms will determine the correct diagnostic procedure to use.
The presence of DTCs which begin with "U" indicate some other module is not communicating. The specified procedure will compile all the available information before tests are performed.
Step
Action
Yes
No
Did you perform the Battery Inspection/Test?
Go to Step 2
Go to Battery Inspection/Test
Go to Step 4
Access the Class 2 Power Mode in the Diagnostic Circuit Check on the scan tool.
Rotate the ignition switch through all positions while observing the Class 2 Power Mode on the Scan Tool. Refer to the Serial Data Power Mode table within the Body Control System Description and Operation in Body Control System for a list of the power mode states that correspond to each ignition switch position.
Go to Step 4
Turn ON the ignition, with the engine OFF.
Attempt to communicate with each module on the class 2 serial data circuit:
• The body control module (BCM)
• The driver information center (DIC)
• The instrument panel cluster (IPC)
• The powertrain control module (PCM)
Does the scan tool communicate with any module on the class 2 serial data circuit?
Go to Step 5
5
Select the Display DTCs function for each module. If using a Tech 2, use the Class 2 DTC Check feature in order to determine which modules have DTCs set.
Record all of the displayed DTCs the DTC status and the module which set the DTC.
Go to Step 6
Go to Symptoms - Engine Electrical
6
Does the scan tool display any DTC beginning with "U"?
Go to Diagnostic Trouble Code (DTC) List in Data Link Communications
Go to Step 7
7
Does the scan tool display any DTC beginning with "B"?
Go to Diagnostic Trouble Code (DTC) List in Body Control Systems
