I popped the clutch and kill the engine. Now the transmission will not engage in any gear. There is a slight clicking sound. Is there a shear pin or something that disengages the drive. The clutch feels the same and the shifter feels the same as usual.
Well, there is one thing for sure the trany is damaged. You will be further ahead looking for another junk yard trany rather than worry about what is going on inside since there is probably parts and pieces inside that would still give you trouble without completely overhauling it, plus a junk yard trany, standard would be easy to come by.
2004 Peugoet: Clutch not going in gears?
http://whoisbyme.blogspot.in/2012/05/peugeot-307-clutch-will-no-go-in-gears.html
Engine stumbles and shuts off in forward gear
on Toyota Land Cruiser?
http://schematicsdiagram.blogspot.com/2012/01/engine-stumbles-and-shuts-off-in.html
Transmission problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-problem.html
Car
engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
Manual
Transmission Clutch System Failures?
http://repairhelpcenter.blogspot.com/2011/11/manual-transmission-clutch-system.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Manual transmission very hard to shift from one gear to another?
http://repairhelpcenter.blogspot.com/2012/01/manual-transmission-very-hard-to-shift.html
Dodge manual transmission will not go in reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
These details will help.Keep updated for more help.
Thanks.
