i have a bissell flip it and the tank were you put the floor cleaner in has a rubber valve in it , the rubber valve has fallen out and the cleaning soultion just pours out i bought it at wal mart about 2 years ago and it works great just need a new tank for it any wear to get one in vancouver canada
You just need to replace the cap and valve part # 2036919, You should be able to order the part thru Bissell.com, or they will tell you who you can call close to you.
I was using this machine and a belt fell off. when we opened the vacuum, we found that there was a...
(More)
I was using this machine and a belt fell off. when we opened the vacuum, we found that there was a belt, have no idea where the second belt goes. is there one on this machine? M086925 dirt devil vision.
the ribbed hose is broken just below its attachment point to the dust canister its an easy fix but i...
(More)
the ribbed hose is broken just below its attachment point to the dust canister its an easy fix but i cant find parts anywhere
When I step on the front of the vacuum so I can lower the upper part to start vacuuming, something...
(More)
When I step on the front of the vacuum so I can lower the upper part to start vacuuming, something is catching and it is very difficult to release the upper part. Any thoughts?
I'm trying to use the reverse flow hole on my Miele s712 to blow up an air mattres. None of my...
(More)
I'm trying to use the reverse flow hole on my Miele s712 to blow up an air mattres. None of my fitting appear to fit so I can use the hose. Is there something I'm missing? Is there a trick of the trade? Or am i missing some gear. It's new, out of the box but I just can't get the hose onto the reverse flow. The Poduct is a Miele S712 vacuum dispite what this system has allowed me to enter. ; )
