Konica Minolta magicolor 2300DL Laser Printer
Problem for Konica Minolta magicolor 2300DL Laser Printer
I have followed the instructions exactly for
By k2power on Sep 01, 2009
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and replacing it a couple of times, turning the printer off and on -- nothing. Now what do i do?
Comments:
Sep 01, 2009
- Okay, I tried it, same error message comes up almost immediately. I also tried the solution offered to one of your other customers of manually rotating the carousel past the new cartride. Tried it multiple times, no luck. What next?
Sep 01, 2009
- My Konica Minolta Magicolor 2300DL will not recognize the new black toner cartridge i've installed according to the product directions. Yes, i've tried unplugging and reinstalling and i've tried the other solution, manually moving the carousel past the new cartridge. Multiple times. The error message: "Replace toner black" remains.
Sep 01, 2009
- I just got back from the computer store where i exchanged the cartridge i bought yesterday for a new one. I popped the new one in and it worked the first try. I just got a defective cartridge. It happens.
Thanks for your lengthy reply. Sorry for the trouble.
Solution #1
posted on Sep 01, 2009
Somewhat Helpful)
justaskjoe
Rank: Guru
Rating: 85%, 2090 votes
hello, i can help you. Unplug your printer, remove the new cartridge, plug in the printer and replace the new toner cartridge.
Repeat those steps if need be, but generally those steps solve the problem
Was this helpful?
Yes
No
Solution #2
Very Helpful)
micromatikal
Rank: Wiz
Rating: 84%, 240 votes
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Comments:
Sep 01, 2009
- No worries, it sounded like that was the case, I was going to say if those instructions don't work then you have a bad cartridge!
Good deal, if you could, please come back to the site when you get a chance and rate my answer, otherwise I get no credit for the help. 4 Thumbs is always good! ;)
Thanks
Tim
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Konica Minolta magicolor
Questions and Unsolved Problems for Konica Minolta magicolor
Do you recommend Konica Minolta magicolor 2300DL Laser Printer?
Answer
Answer
where can i find drivers for a 2300dl to use on windows 7?
Answer
My Konkca Minolta 2300DL Laser printer is folding pages. Usually it is just the first sheet when I... (More)
Answer
printing so that the page gets cut off on the left hand side and there is an inch blank on the right... (More)
Answer
pages get stuck, won't feed thru the machine...getting error message: service call 15 H...any... (More)
Answer
Just replaced the drum because I was getting vertical striping on the left side and I'm still... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
