Question about Arris WR850G Router (DHWR850G)
Motorola WR850G router
I have DSL. Everything is hooked up correctly, but when you go online things won't load. You have to refresh 5-6 times to get things to come up. When I use the laptop wirelessly from the router it's almost unbearable to deal with the slowness. What could the problem be?
  • 72 Answers
Slow speeds is caused by interfearace from cordless phones. 2.4ghz. also could need a power cycle. unplug the power from the back of your dsl modem. unplug the power from your router. shut down your computer. Plug in the modem frist, wait until all lights are green. plug in the router. then when lights are normal on that. turn on your computer. try your connection again. is it slow when you try to acess the router ip address?
Posted on Feb 15, 2008
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
May 15, 2013 | Arris WR850G Router (DHWR850G)
Motorola WR850G
Right off the top I can imagine that the laptop is smirking because it has a battery to get it through the power outage. What may be happening is that the desktop loses it's ip address or the router defaults back to DHCP rather than PPPoE which is where it belongs for DSL. 3 ways to fix this:
1) Reset the power on the DSL modem and wait a minute or two.
2) Go to Start>Run>type 'cmd', Enter, type 'ipconfig /release' then 'ipconfig /renew' then 'ipconfig /all' to see all of the ip addresses for each adaptor and gateway.
3) Go to Start>Run type '' and a logon window appears. User name is 'motorola', Password is 'admin'. A webpage appears showing you are now talking to your router. In the LAN tab choose PPPoE for automatic DSL control settings. You can also temporarily select DHCP to use the 'Release' and 'Renew' buttons here which is the same as the ipconfig commands you did at the Command Prompt in step 2 but reselect PPPoE before you leave the router control panel. You can also select STATIC if you already know your ip addresses but for DSL you normally use PPPoE. If you haven't done this before then peruse all of the other controls that you can access here. (If you are a gamer this is where you set up your DMZ and so on.
Have a nice day, Steve Medley
Aug 06, 2008 | Arris WR850G Router (DHWR850G)
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
My ipod touch wont connenct to the internet
Go to Start>Run and type '', a logon screen appears. User name is: motorola, Password is: admin. A webpage appears which is the router control panel. Now you can talk to your router. If you are using cable broadband then use DHCP, for DSL use PPPoE. All of your Basic, LAN, Wireless, Status, Gaming, Security and Firmware updates are here. For more info and manuals/downloads for your router go here:
Have a nice day! Steve Medley
Jul 03, 2008 | Arris WR850G Router (DHWR850G)
Motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address
and look for WAN options.
Thanks ,, please let me now it worked or not
Jun 09, 2008 | Arris WR850G Router (DHWR850G)
XBox 360 not compatible with Motorola WR850G
Motorola WR850G router may fail to connect to xbox live after update to firmware 6.1.4. I was able to correct the problem. My solution was
Go in xbox >> network config >> IP and use Static option. Set the xbox to an IP in the range allowed by your router configuration. The router IP config range is found in the router config web >> Lan section. Then I set my router config >> Routing >> DMZ IP Address setting to the xbox ip I just assigned to my xbox. Restart router using the restart button on the Basic page of router config. Restart your xbox and attempt to login to xbox live. This solved my problem.
As a side note, on the xbox networking test page, the xbox live status message will allows show they are aware of a problem with xbox live login. This is a lie. For that reason I postponed trying to fix my router problem thinking it was an xbox issue, it is not. Once you finally connect to xbox live you will still notice this incorrect message remains. Microsoft developers ****...
Dec 26, 2007 | Arris WR850GP Router
Motoroal Wireless Router - WR850G
Have you checked fof various malware interfering with communications. Such as viruses, trojans. spyware, adware, etc.
F-Secure, Trend Micro, Symantec, Panda offer online virus scans to detect problems
Spybot is a free spyware detector
Lavasoft's Adware have free and paid versions for adware detection.
These resources may provide an indication of where the problem and even clean it up one time. However, unless there is an installed product you are likely to become reinfected again by returning to the original sources of the infection.
Dec 13, 2007 | Arris Wireless G Broadband Router (wr850g)
Arris WR850G Router (DHWR850G) Logo
136 people viewed this question
Top Arris Computers & Internet Experts
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
