Question about Sony Playstation 3 (PS3) Console
PS3 cant go online with Belkin N1 wireless router
I get the "DNS Error - 80710102" even after a configuring a static ip address on my belkin N1 wireless router. If i let the ps3 try to set up using the easy option on my ps3, it fails when it tries to connect to the PS network with the same dns error. Please help.
  • 7 more comments
  • Anonymous Dec 28, 2007
    It jsut says DNS error, with the numbers.
    and it gets to the Connection test and the internet connection fails, but the IP goes through.
  • Anonymous Jan 26, 2008
    umm, i got a similiar problem with the WRT54G Router.....it finds the IP fine but when it test the internet connection it always fails.......and i got a 100% signal strength.....can i get a step by step guide on what to do?
  • lynell_salaz Aug 14, 2008
    my ps3 is saying ip is need to go online
  • bufalinip Aug 24, 2008
    When i complete my network setup and run the test everything connects until i get to ps3 network connection it fails
  • cheechilo2 Dec 16, 2008
    I have the belkin wireless router and i cant seem to get connected. I cant get an ip address. I even tried entering everything manually.Can someone help?
  • lisaheaven Dec 28, 2008
    same prob as everyone else it seems. ps3 working fine for a couple of days in regards to wireless connection. Now I keep getting connection "failed" blah blah blah - I don't know which is driving more nuts, my son nagging me that this thing is broken or me not being a ble to fix it. Please help.
  • hilljjake Dec 28, 2008
    ive got a belkin N+ wireless router and every time i try to connect to my i get a variety of codes. ive got about 75% when i shows up but usually it does detect any access points. i think it might be an error with the PS3 because ive got 2 laptops connected and it didn't work with an ethernet cable
    can someone please help me?
  • nascarjohn79 Jan 11, 2009
    I cant go wireless with my ps3 with my belkin? Its is saying the same error as this one. Also the wireless light is blinking on my belkin router? please help.
  • Anonymous Mar 19, 2009
    the ps3 connects no problem without security enabled, when i enable WPA2 security and enter my password PSK, it tries to exchange keys and then fails with an 803...... error!
I have exactly the same issue as some of you above. As soon as I start my PS3 I manage to log onto the network for anywhere between 2 seconds and 2 minutes before I get the dreaded 80710102 error and have to reboot the PS3 to reconnect. I wrote to Belkin tech support and got the following reply... I Haven't tried it yet so don't know if it really works but thought I'd post it up here in case it helps anyone else out...
Hi Antony,
Thank you for contacting Belkin Technical Support.
We understand that the router does not support PS3. We apologize for the inconvenience caused.
A) To isolate the problem, please follow the steps given below to update the firmware and configure the router:
We recommend that you update the firmware from a computer that is connected to the router with an ethernet cable.
Please download only the relevant firmware on the router from the link given below. The firmware file would be according to the router version:
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8635uk4A&aid=14489&scid=0
and save it to the computer.
- To update the firmware, log on to the router`s web interface by typing in http://192.168.2.1 in the address bar of the browser. The computer should be
Note: If you have changed your Router’s IP address, use that IP address.
- By default, the password is blank. Click the "Submit" button.
- Click on "Firmware Upgrade" under the option "Utilities".
- Click on “Browse” and select the bin file that you have downloaded.
- Click on “update” and follow the wizard.
- After updating the firmware, restore the router to factory defaults by clicking on "Restore Factory Defaults" under "Utilities".
- Reconfigure the router.
Please follow the steps given below for configuring the router:
- Disconnect the computer from your Modem provided by your "Internet Service Provider" (ISP) if it is connected to the computer.
- Reset the router to "Factory Defaults". The reset button is found at the back of the router. The reset procedure is,
- Unplug the power cable and then plug it back again. Wait for 5 seconds.
- Locate the reset button (inside a hole) at the back of the router.
- Hold down the reset button till the power-light turns solid, and then release it.
- Connect the router to either the telephone line or the filter.
- Connect the computer to port number 1 of the router.
- Make sure the corresponding lights are lit. The telephone light should be ON and solid.
- Make sure your computer has a valid IP address by following the steps given below.
1. Click on “Start” -> “Run” -> and type “CMD” and click “OK”.
2. Type “ipconfig” in the black window and check the IP address.
3. It should be in the range of 192.168.2.x, where “x” ranges from 2 to 254.
- If it is not a valid IP Address, please assign a static IP address, "Subnet Mask", “Default Gateway" and "DNS Addresses" in the computer by referring to the link below.
http://web.belkin.com/support/kb/kb.asp?a=2824
- Please reset the Internet Explorer browser settings by following the steps below.
- Open Internet Explorer. Click on “Tools” -> “Internet Options”.
- Under the General tab, click on “Delete Files” under “Temporary
Internet Files” and select "Delete all Offline content" box.
- Click on “Clear History”.
- Under the Connections tab, select “Never Dial a Connection” and
click on “LAN settings”. Uncheck all the options and click on “OK”.
- Under the Advanced tab, click on “Restore Defaults”.
- Click on “Apply” and then “OK”.
- Log on to router setup page by typing “192.168.2.1” in the address bar of the browser. By default the password is blank.
- On the left under “Internet WAN”, click on the option "Connection Type".
- Select “PPPOA”, (If it is ADSL)/ PPPOE (If it is DSL) and click on “next”.
- Type in the user-name and password and then re-type the password given to you by your ISP. Make sure you type in the full user-name.
For Example, the format for the User-name should be "yourusername@yourISP.com or .net"
- Also confirm the settings of “VPI/VCI”, “Encapsulation” values from your Internet Service Provider (ISP) and configure the same.
- Change the “MTU” to “1400”.
- Click on “Apply Changes” button at the bottom. Wait till it saves the data.
- Click on Home on the right top corner and then click on the "Connect" button. You should be able to go online.
B) Configuration of PS3:
Please contact Sony and assign static IP address and DNS on the PS3. The static IP address should be assigned in the range of the router. For example: 192.168.2.200. The IP address you assign should not be used by any other device on the network. Please confirm the ports to be opened for the PS3 from Sony.
1) Please follow the instructions given below to forward the port numbers for PS3 on the router:
- Please open the Internet Explorer and in the address bar type in "192.168.2.1" and "Enter". The computer should be connected to the router with an ethernet cable.
- Leave the password blank and click on "submit".
- Click on "Virtual server" under the "Firewall".
- Enter the port number under "Inbound port" & "Private port".
- Enter the Static IP address of the PS3 under the "Private IP address".
- Check the "Enable" box and click on "Apply changes".
2) Please follow the instructions given below to enable UpnP on the router:
- Log on to the router web interface at http://192.168.2.1
- Click on System setting under "Utilities".
- Against the heading "UPNP Enabling", choose "Enable".
- Click on "Apply changes".
Note: The NAT feature on the router is enabled by default.
If the problem persists, please get back to us with the following information:
1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or Static).
2. Name of the Internet service provider (ISP).
3. Version number of the router. You would find the version number on the bottom of the device. It would be a number in a series of thousands with a prefix “ver.”. Please confirm if the router is F5D8635?
4. Using the router, if the connection is stable on all the wired and wireless computers?
5. If the PS3 works fine with other networks?
6. When does the error come up? If it comes up for both, CAT5 and CAT6 cables?
Posted on May 28, 2009
  • 182 Answers
When you go into network settings in the settings menu bar, pick the first option settings and connection status list. your signal strength should be a minimum of 90% if not it will not sign in i had simmilar problem so i moved my wireless hub just outside the room i was using the ps3 in and now the signal strength is at least 95% and i have no problems. please feel free to ask any questions.
Posted on Jan 07, 2008
I had this problem initally when trying to connect with my Belkin N1 and my ps3; and even my wii wirelessly. I noticed when I FINALLY got it to work, Belkin reads the 'Default Router' on your ps3 as your 'IP address', and vice versa
SO
When entering in your network settings on your ps3, you will need to enter in your 'Default Router #'s', where is ASKS 'IP Address' #'s
AND
Where you enter in the "IP ADDRESS" on your ps3m you will need to put in your 'Default Router" #'s.
I believe this should help, I hope it does. Take care
Posted on Feb 07, 2009
I have a Belkin N+, but I get the same error message.  If you just don't touch it from start up and let it continue trying to connect, it'll work fine.  Sometimes it'll connect right away, sometimes it'll take about two minutes.  Once it's connected, you're all set.  If you stop the connection and try to restart it, you will most likely time out before you're connected.  You have to let it auto-connect at start up.  I've been doing this for a few months with hardly any problems.
Posted on Feb 18, 2009
Same i even tryed rebooting is it my router does belkin not work why dont they make it easier for gods sake
Posted on Sep 15, 2008
Same thing becklin wireless router 100 signal no internet connection drives me mad tried restarting everthing deos my nut in
Posted on Jul 11, 2008
SAME PROBLEM HERE. TRY RESTARTING ROUTER AND MODEM AND PS3. THIS USUALLY WORKS FOR ME.
Posted on May 22, 2008
I how the same proble so i see if putting the wireless router near my PS3 will work then ill move it later thanks for the help.
Posted on Mar 06, 2008
I have 100% signal and still have the same problems described above...
Posted on Feb 06, 2008
I can't get my Ps3 online at all....
I think My Motorola Modem is the problem. I dont have cable is that a problem, too?
Posted on Dec 29, 2009
  • Zffranciscus Dec 29, 2009
Am lost my cd how do i install my f5db231-4 wireless router
Please follow steps to configure router
  1. Open Internet Explorer and enter the address http://192.168.2.1
  2. Leave the password field blank and click LOGIN.
  3. Click INITIAL SETUP.
  4. Select STATIC IP ADDRESS then click SELECT
  5. Now enter in the IP Address, Subnet, and Gateway, then click ENTER. (If you don?t know the IP Address, Subnet, or Gateway, call technical support and they will provide you with that information.)
  6. Now enter in the DNS Addresses, then click ENTER.
    a. Primary DNS = 209.193.72.2
    b. Secondary DNS = 209.193.68.2
  7. Now click ENTER.
now try to go online
Hope it can resolve your issue
Thanks for using Fixya
Apr 13, 2010 | Belkin (F5D8231-4) Wireless Router...
My son's new Xbox Live cannot / will not connect with our wireless router, even though it recognizes it. I have a Belkin 802.11b
1) Get connected to belkin's wireless network or wired network
2) Once you get connected, it may not be able to go online on XBox Live
3) Go to any computer that is going online with the router
4) Type in 192.168.2.1 in the address bar of your Internet explorer
5) This will open up router interface(here we have to do some settings)
6) In the left hand side column, click on FIREWALL.
7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes.
8) Under FIREWALL(in the left hand side column), click on DMZ
9) Make a "check" on enable and under Private IP: 192.168.2.25. Click on Apply Changes.
10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration
IP: 192.168.2.25
Subnet: 255.255.255.0
Router: 192.168.2.1
11) Now select manual configuration for DNS settings.
Primary DNS: 4.2.2.2
Secondary DNS: 4.2.2.1
12) Restart both Belkin and Xbox
13) It should connect to XBox Live now...
Jan 17, 2010 | Belkin (F5D8231-4) Wireless Router...
I would like initially to be able to remotely access my HP Home Server attached to my Belkin N1. In the future I might want to host a website and remotely access that site. ???
You need EITHER a static legal IP address, purchased and rented from your ISP OR use a dynamic DNS service to register your system once connected to the internet.
Look up dynamic dns on google.
You also need to be able to set up the belkin to allow requests from outside to be passed to your computer, but remember the hackers! password protect it, restrict the ports in use.
Nov 11, 2009 | Belkin N1 Vision Wireless Router
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
PLAYSTATION WONT SIGN IN KEEPS SAYIN DNS ERROR
You must change the wireless channel of your router and do a power cycle. Just turn off your router for 30 seconds then turn it back on.
Jun 09, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
PS3 cant go online with Belkin N150 (I think) wireless router
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings for the UPnP function and disable it. If you haven't changed the password on the router, the default password is blank, i.e., no password.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 online
go to ur network settings and then go to deatils and it tells u ur ip adress and dns server and othe stuff to type in
Jul 05, 2008 | Sony Playstation 3 (PS3) Console
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Router blocking my downloads
k i think why its happend probabally there is a port blocking is there in the belkin router so try this set static ip address on the pc in the range of belkin>and login to belkin router and enable DMZ on the belkin router the dmz host ip should be the one which u assigned statically on the pc
Oct 13, 2007 | MSI Wireless-G RG54G3 Router
Sony Playstation 3 (PS3) Console Logo
16,411 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
