Question about Admiral AW22 Top Load Washer
Admiral washer bought yesterday
Hi I just purchased my washer last night. It wont hold water. It all drains out from underneath. The drain hose is not too low. The water is not coming from there. It's coming from underneath somewhere. I am going to have to return it but really dont want to. i just wanted to see if maybe there is something that i could fix on my own before i return it. Any ideas?
  • Chris d Jan 17, 2008
    I have the same problem just started happening also now the motor to spin the washer went because of the watter all it does is hum
Another Solution is the waste water pump itself. (not a very expensive part) If the washer has been overloaded a sock or other small article could have gone over the side of the basket and into the waste water system clogging the pump and causing water to come out the hoses under the washer. not a hard fix just a few clips and 2 hoses
Posted on Jan 31, 2008
    Problem Solver:
  • 19 Answers
THERE IS A CLIP AT FRONT OF LID ABOUT 4 INCHES FROM BOTH SIDES THAT HOLDS FRONT ON. SLIDE BUTTER KNIFE BETWEEN CABNET AND TOP AT THIS PUSH IN TO RELEASE THE TWO CLIPS THIS SHOULD LET FRONT COME FOWARD AT THE TOP THEN LIFT UP TO REMOVE THIS WILL LET YOU SEE WHATS GOING ON. PROBLY A HOSE, BUT MAYBE SEAL AT CENTER ON BOTTOM OF TUB. IF SEAL TAKE MACHINE BACK. SEAL VERY COSTLY TO FIX. HOPE I WAS A HELP. FXIT
Posted on Jan 30, 2008
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Admiral side by side model HMG53168. There is ice in the bottom of the freezer, and water on the floor. The drip pan is dry.
Ronald Coons' answer was helpful, pointing me in the right direction. Sure enough, the drain was frozen shut. I had looked for a drain but didn't see one in the bottom of the freezer, didn't realize it was in the back. Anyway, I also noticed the drain tube sloped UP underneath the fridge, then dropped down into the drain/evaporating tray. That guarantees that there would be water sitting in the tube, ready to freeze. I don't worry about critters going up an empty hose, so I removed the clamp holding the hose, cut some off of the end so the hose can now go DOWNhill from the drain to the tray. If that doesn't fix it, I'll go buy some copper wire and implement the rest of Mr. Coons' solution.
Dec 19, 2010 | Admiral Refrigerators
Washer will nto hold water during fill cycle - the water drains right out the hose
The drain hose needs to be elevated to at least 30 inchs above the floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 29, 2010 | Admiral 32 cu. ft. Washer
My washer wont hold water
Hi
Make sure your drain hose is not sitting on the floor.
You need to make sure the drain hose goes up to the hight of the tank and then back down to the drain.
If the hose is sitting low, then gravity will just drain the water out.
Let me know if this is not the case and I will dry and diagnose if there is a nother problem.
Ash
Nov 06, 2009 | GE WBSR3140DW Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Whirpool washer wont work
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Jul 26, 2009 | Whirlpool CAM2752KQ Top Load Washer
WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Jul 15, 2009 | Kenmore Washing Machines
Water leaks under machine
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Mar 02, 2009 | Admiral AW22 Top Load Washer
Washing machine
hi there,
sounds like the drain pump. check the drain hose first though, as you may have something caught in it.
Sep 30, 2008 | Admiral AW22 Top Load Washer
We bought a washer yesterday. When I went to fill it up this morning the water would not fill but just drains, while the water is running, please help, I think it is something simple/
The drain hose is too far down the drain. Pull out excess hose from drain and leave only 8 to to 12 inches. Using zip tie or other method, secure drain hose to water hoses to prevent drain hose from jumping out.
Jun 08, 2008 | GE Washing Machines
Admiral AW22 Top Load Washer Logo
65 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
