Question about Dell UltraSharp 1905FP 19" LCD Monitor
Unable to adjust contrast
Under the Brightness/Contrast option in the main menu contrast is grayed out so I cannot adjust it. I have a dual monitor setup and the situation is the same on both monitors.
  • Anonymous Jan 14, 2008
    the main menu does not go away! when i tyr to play my comuper games (sims 2) it pops up in the middle of the screen and does not go away! hwo do you navigate around the main menu!?
  • Anonymous Apr 11, 2008
    me too
Http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
Posted on Oct 07, 2008
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
How to adjust the brightness and contrast of
look you have to see or find the menu bootoms in the bottom of the scree or on the back left or right and you find them just + or - the menus the brightness and the contrast will be under your control
Oct 25, 2009 | ASUS MK241H Monitor
Cannot change the brightness
to adjust brightness levels you might want to modify ONLY the brightness, contrast and gamma settings. Others might mess up your colors or god knows what. You can also set up the GPU's brightness settings by going to the gpu's control panel, usually opened by right clicking the desktop and selecting your video card's control panel option. Then adjust the brightness, contrast and gamma options to suit your needs. Hope that helps!
Jun 10, 2009 | Hannspree HW191D LCD Monitor
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Retrace line on monitor
To prevent serious damage and extend the life of your monitor you need to adjust the main brigthness control of it. it is of the LOPT/Flyback transformer inside of your monitor!
check also for cold SOLDER joints on the main pcb and also on the crt neck Board.
Nov 16, 2007 | Sony STYLEPRO CPD-E540 (Gray) 21 in.CRT...
Dell UltraSharp 1905FP 19" LCD Monitor Logo
900 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
