Question about Canon DR-9080C Path-Through Scanner
Black area above the scanned image.
I am having a problem with the scanned images coming out with a large black line across the top of the image. It looks like the scanner is starting before the paper goes across the lamp.
  • robday Dec 06, 2007
    This is a high speed scanner, so I don't think it has a drum. If it does let me know where it is.
  • robday Dec 10, 2007
    I reinstalled the drivers and that fixed it. Thanks for your help.
  • 490 Answers
If you set Automatic brightness/Contrast this happens. Try manual setting. Adjust different settings and select the best suited for a particular type of drawing. The scanner takes couple of milliseconds to judge the best lighting, by then the paper has moved little. This area appears black. This is easily solvable.
S. Mohan, Chennai, India
Posted on Dec 10, 2007
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
I have a 2" black line at the top of the tv. And also smaller black lines across the middle of the tv.
Dear Jeff,
It seems like the Horizontal IC in your TV is dying. This and the Vertical IC is responsible for displaying images on your TV. (Look at your TV through your Phone Camera and you will see upward scrolling lines.This is the Horizontal IC in action.)
I would strongly advise you to get your TV repaired immediately.
Oct 19, 2012 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black line across the top of every print on bh c250
Hi first do a cmyk test chart of each color if it happens when you do black copies then check the black imaging unit as it is not being cleaned and will give you black lines replace black drum unit
if it is on color copies black copies then the other thing to look at is the transfer belt unit and you may need to change the transfer belt
do the CMYK and you should get each color fully covered on each page see if there is any lines on the sheets in the same area you are getting the lines if so replace that color drum
Feb 12, 2011 | Minolta C250 Color Copier
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
Line showing up on scanned photos
You can remove the line by checking the glass in the auto document feed area (the small glass area about 1" X 8"). Check the glass for either white-out or a black spot (ink) and wash it off using alcohol or glass cleaner and a lintless towel which ever works. Sometimes the spot can be more easily found if you line up the line on the paper to the glass.
Good Luck!
Rich
May 02, 2009 | Computers & Internet
Black area in photograph
Unless you are using high-end Nikon Speedlights with camera and flash set for Auto FP High-Speed Sync, your top flash sync shutter speed on the D80 is 1/200 second. The black band you are seeing at faster shutter speeds is because the second curtain of the shutter begins to close before the first curtain reaches the fully-open position (which is when the flash fires). The higher the shutter speed, the shorter the gap between first and second curtains. To get full exposure with flash, there must be an instant when the shutter is fully open -- first curtain completed travel, second curtain not started yet.
"As the speed increases the final image should get lighter" applies to ISO speed. Higher shutter speeds mean less light reaching the sensor, but that's not the cause of the black bands.
Mar 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
White line at top of screen on some channels/shows
Most certainly a warranty issue! take it back and get a new one. this is a common problem with these particular models.
Feb 11, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Microtek scanmaker 9800xl problem
9800XL - fix for failing lamps
1) Unplug the scanner - not just from the computer, but also from the AC!
2) If your unit has a Transparent Media Adapter on top, disconnect it from the back of the scanner, lift it off and set it aside.
3) Remove the four white slotted screws at rear of unit.
4) Remove the four Philips screws in the area surrounding the glass scanning bed.
5) Carefully lift the top off, and set it aside.
6) Inside the scanner, there will be a black metal contraption that rides the two steel rails in the unit. On the side of the contraption are some black screws. This device contains the lamps as well as the image sensor. Unscrew the 4 screws that hold the top cover on. Lift off the top cover. You may gently move the thingy along the rails for easier screw access, it will automatically reseat itself when powered on.
7) Inside this area, you will see a small circuit board. Disconnect the two connectors on it, remove the two screws that hold the board in place, and lift it out.
8) On this circuit board there should be one or two damaged capacitors. Unsolder them and replace them with 2 33pF 3kV capacitors (cost: under $1.00)
9) Put the whole thing back together, and it should function properly.
Feb 12, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
Printing and scanning problems
Go to " Dell All in One centre"
Click on maintain/ Troubleshoot on top of the page.
Then click maintain or fix quality problems.
then choose the problem you have.
It should be sorted,
Let me know how it goes.
Jul 27, 2006 | Dell 962 Photo All-In-One InkJet Printer
Canon DR-9080C Path-Through Scanner Logo
301 people viewed this question
old marine
old marine
