Question about HP PSC 1410v All-in-One Printer
Programming could you please tell me how to program a regency r1070 scanner, i have an error message (Fr Err), could you please help
  • Lj Whitaker
    Lj Whitaker Jul 26, 2008
    when i scan its shows fr err
    Genius:
  • 1,689 Answers
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
http://www.w7fg.com/index.html
for scanner and old radio manuals.
from WikiAnswers
good luck
-voodoomox
Posted on Jul 26, 2008
    Guru:
  • 1,463 Answers
See solve a problem link here HP PSC 1410v All-in-One Printer/Scanner/Copier
riz.
Posted on Jun 28, 2008
Where can I buy an antenna for a Regency model R1070 scanner
search ebay for "regency r1070 scanner antenna" and many will pop up. Also Radio shack..
Jul 09, 2012 | Uniden Radio Communications
MY REGENCY SCANNER R1077 PROGRAMMABLE SAID FR FREEZE AND I PUSH SCAN NOW IT WANT DO ANYTHING
I have a r1077 programmable scanner I'm trying to program it and I'm having trouble anything I key in keeps reading fr err in it every time. What should I do to fix this problem
Mar 23, 2012 | Radio Communications
How do you program a Regency Programmable Scanner R1070?
Regency R1070 Frequencies for people with no manual
These are the ranges it supports.
30-50 Mhz
144-174 Mhz
440-512 Mhz
To make it scan, first set the range by pressing Manual and then Search. It will ask for the LOwer end and the UPper end of the range. Enter them, press Scan and then Search, and it will start scanning. When it locks and you want to keep going, hit Search again. You can press Delay to stop at a channel temporarily. To save a frequency in memory, hit Manual and pick a number, then type it out and hit Enter. When you have a few channels saved and you want to check up on each of them, Scan scans through memory. The Lock button is to skip a particular channel while scanning.
That's pretty much the whole manual right there.
Jan 30, 2012 | Radio Communications
I can't open any progrmas on my TI-84Plus , it only gives : Error and 1:QUIT can you experts help me?THNX
You should give the whole error message.
I created a bogus program and archived it.
Then I tried to execute it. I got the messages: ERR Archived 1:Quit 2:Goto. When I tried to edit it I got ERR:Archived 1:Quit.
Your program is archived. You must unarchive it.
To Unarchive. Press [2nd] [MEM][2:Mem Mgmt/Del] [ENTER]
Scroll down to [7:Pgrm]. Archived programs will have a star at the left. Highlight the program you want to unarchive and press [ENTER]. The asterisk disappears. Press [2nd][QUIT]. Your program is ready to run or to be edited.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-84 Plus Calculator
Regency scanner r1070 error message fr err, will not scan
i have same problem with my scanner what my prob was is moisture got into the radio and it sat for while and corosion ate one of the pins of a crystal causing it to have fr err on any channel i put it on replacing the crystal fixed it for me but with scanners anything could be wrong
Jul 18, 2009 | Radio Communications
Want to workaround Shrinker.err to be able to download programs. Can it be disabled in any way?
I found that "shrinker.err" is an error
that you get if the product PowerZip 4.50
is installed and fails to start. PowerZip is a Windows utility, a compression tool.
The shrinker.err error is corrected in the PowerZip 5.2 release, the newest version
and that should fix your problem.
This program has nothing to do with any virus.
Hope this helps, Please leave rating...
May 02, 2009 | Computers & Internet
Regency 1099 Scanner
Fr Err usually means that the freq entered into a certain channel is too high or too low for the band of the scanner. Also could mean that the freq's have been lost out of the memory. Maybe a dead memory battery, or been unhooked from the wall too long and lost it's charge. Been a loong time since I've seen one of those models,,, Let me know if it helps,,, Mechanic
Nov 04, 2008 | Radio Communications
How to program an old regency 1060 scanner
I'm not too sure about this particular model, but other Regency variations require you to push the "Manual" button, enter the channel number you want to set (usually 01-09 for single digits) and then enter the frequency you want. On some you may need to enter the frequency first and then the channel number.
Oct 11, 2008 | Uniden BC72XLT Handheld Scanner
Regency R1070 scanner Fr Err
if an out of band frequency is put in that channel you will get the Fr Err message as well, just put in a frequency within the scanners specs
Sep 24, 2008 | Radio Communications
Uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
Apr 30, 2008 | Uniden BC60XLT-1 Handheld Scanner
HP PSC 1410v All-in-One Printer Logo
245 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
