Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 2165 Mower Shuts Down
I own a Cub Cadet HDS 2165 mower with a Briggs & Stratton engine.
After mowing for 35 to 45 minutes the engine dies.
After waiting for a couple of hours, I can start it again but it only lasts about 20 minutes after that.
I've checked the gas and that isnt the issue.
What could it be?
  • 67 Answers
Did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Posted on Sep 01, 2009
SOURCE:
How can I tell if my starter is bad on my cub cadet rtz mower
Check for spark
Have to get the test plug for small engines
Is the battery years old & partially dead?
Is the oil clean & full
Won't turn over or won't start?
Clean the flywheel & ignition coil or whatever
system it has for spark
Check for intake gasket leaks.
Did the meter always go down to 9.8 when it did start?
Your best to work on things & learn-- when they work correctly,
not wait for years then be lost
May 08, 2014 | Cub Cadet Garden
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I need a diagraphm for a Cub Cadet lawn mower to put belt back on
To get correct diagram, will need the model number of the unit. Not the model off the engine, but off the chassie.
Sep 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 with a Briggs & Stratton shuts off when hot. Appears to be vapor lock, as can see fuel filter emptying. After filter cools, it refills. Anyone have a solution?
It could be vapor lock. Vapor lock is a condition where the hot gasoline turns into vapor bubbles either in the fuel line or carb. When it happens, the vapors will cut off fuel flow thru the carb, essentially causing the engine to run out of fuel. You should re-route or isolate the fuel line away from the heat of the engine and install an inline fuel filter close to the carb. Also make sure that the cooling fins are not clogged up with trash or something that is causing the engine to overheat. I would also check the gas cap. Make sure the vent is clear and clean around the gasket in the cap. This can sometimes cause similar problems. Hope this helps and good luck.
Jun 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,297 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
roeb
Marvin
Marvin
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
