Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable  Drive
Problem for Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB...
HOW DO YOU USE A USB STICK
By marebare59 on Aug 31, 2009
Best Solution
posted on Aug 31, 2009
Very Helpful)
Geekman
Rank: Guru  Toshiba Computers & Networking  Expert
Rating: 85%, 2014 votes
There are various types of USB sticks or adapters. The most common is an USB memory stick and they come in memory capacities from 256Mb to 32Gb or more.
The USB memory sticks are use to transfer data from a computer to a memory stick and vice versa (ie. copy data from one computer to another computer).
To copy data to and from a USB memory stick, all you have to do is to plug the memory stick into the USB port of a computer, the computer will recognize it as an external memory device.
Wait a few seconds and click to open the memory stick, just like openning a folder on your hard disk. You can then open the hard disk and copy data files from the hard disk to the memory stick in the same way if you were copying data to a floppy disk.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
KingDWS
Rank: Guru  Computers & Networking  Expert
Rating: 90%, 183 votes
This is pretty easy and once you've used it on your computer you will be glad you have it. They are very handy.
The stick has a usb connector on the one end. You may need uncover it. There should be a plastic cover that pops off on the one end. It should just pull off.
Once you have the cover off then you need to find the usb port on your computer or laptop. Simply plug it in. If it doesn't want to slide it flip it over. It's just upside down. The laptop of computer will usually beep when it detects but don't worry if it doesn't.
You should now see a few messages appear near your clock. Some will say usb device found, then mas storage and perhaps even say your Toshiba usb. That might take a minute the very first time (much quicker the next) before you can use it.
One windows has found and installed it then it is ready to use. Go to my computer and look and you should see a C drive and perhaps D which is usually you cd or dvd rom drive. You may also see other things such as card readers. What you are look for is either Toshiba mass or usb storage device.Or something along that line. That is you usb memory stick installed and ready to use.
You use the stick just like any other drive. You can store anything on it including programs music movies and so on. When you save or copy instead of just saving to my documents save it to the usb stick. And the same if you want to use or copy a file that is on it. It will show up under my computer or anytime you save as another drive (as long as it is plugged in). Because they are seen this way you can erase or delete files, make directories or do almost everything else you can on a normal hard drive. They are just a super useful thing to have. You may find yourself buying a few of these so you can have one for pictures, another for documents, and so on because they are so handy.
Once the files are on it or you are done with it then then you can remove it from the usb port. USB sticks are hot swap things, in other words you can plug them in and unplug them even after the computer is running. They are meant to work that way unlike most other parts. This means you can quickly put in in one computer copy files to it take it out and put in in another all without having to reboot or do anything annoying.
Just so you know to remove the stick you should click on the little usb icon that appears by you clock, a new window will pop up and should list all usb devices including your usb stick Click "stop" on your device. In a second it should say something like you can now safely remove your device. Pull it out of the port close the window and you are good to go. Now some versions of windows and some usb sticks don't really care if you just yank them out. It will never hurt the computer end of things but on larger sticks that have security stuff built in this will and does scramble them up and they are toast. So make sure you know if your stick has this so you can remind yourself about yanking it out.
Enjoy!
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Toshiba 1GB USB 2.0 High-Speed
Questions and Unsolved Problems for Toshiba 1GB USB 2.0 High-Speed
Do you recommend Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive?
Answer
Answer
My Toshiba thumb drive can't be detected anymore, is there any idea that i can get all the files out... (More)
Answer
I've a Toshiba 2 GB usb flash drive which has become write protected & even after low level... (More)
Answer
My wife accidentally washed her flash drive in the washing machine. Now it will not work. Any help... (More)
Answer
By mistake, I formatted my Flash drive, losing Operation manual, Ready Boost feature and Lock... (More)
Describe your Zip and Other Drives problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Zip and Other... Experts
Top Computer & Laptop Repairmen
in , NY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
