Question about Kenmore 24 in. 16032 Built-in Dishwasher
Cannot get lock button to go off
All lights light up including lock button. the dishwasher may run for 15 min. or 1 hour. cannot get it to run a normal cycle. sometimes it comes on and drains and then i can't get it started for several hours.
  • susangreth Dec 20, 2007
    I am having them same problem. I can get the wash cycle to turn on, but every few minutes the lock light starts blinking and it restarts the cycle.
    Novelist:
  • 148 Answers
1. possible timer issue.
2. motor wear. the motor may be heat protected. if it is worn, or the pump it is attached to is worn, it may overheat. when that happens it shuts off until it cools down. if there are sufficient sensors and boards, some appliances will send information to the timer of an interrupt, which might reset the cycle.
3. drain plugged. if water does not pump out, the rinse cycle will continue to run on many units. this can relate to a general pump problem as well as a plug. inspect the hose for kinks and if it goes to an air gap at the sink, it may be plugged there. lift of the chrome dome, there is a cap at the top of the device you can see once the chrome dome is off. then, put a bowl over the air gap with a towel around the gap on the back side only so the water does not run onto the counter (if you care) and then run the rinse cycle if you can and let the pump out run directly to the sink. that will clear a clog. often clogs come to the top of the air gap, hit the cap and stay there. when you open the cap to inspect, you may not see the plug, as it drops back down the hose until pump is pushing water up the hose again. lawn sprinklers have the same problem sometimes. the clog drops down when you remove the sprinkler to see why its clogged.
mark
Posted on Dec 22, 2007
Dishwasher will not work. heated dry and child lock lights are lit up. tried holding heated dry button for 3 seconds to turn off child lock nothing happens.
Try finding the electrical circuit that powers your dishwasher. Turn off the breaker for a while (15-30 min.) This may reset the computer to factory defaults.
Apr 29, 2011 | Haier ESD310 24 in. Dishwasher
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Anti theft lock
disconnect the battery for 3 mins
May 04, 2010 | 1999 Ford F150 Regular Cab
Child lock light will not turn off on my kitchen aid dishwasher
ok shut off the breaker for at least 1 min if you have had a power surge you not know it can affect items then turn breaker back on and then push and hold the lock button some times up to 90 sec once you see lock go off then release the lock button then your back in business
Sep 06, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
GE dishwasher won't start
You have a washer control board problem or a burnt connector or both.
Mar 17, 2017 | GE 24 in. Profile PDW9200J Built-in...
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Feb 04, 2008 | Dishwashers
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Kenmore 24 in. 16032 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
