Keeps stalling out
If it starts fine and idles fine but then stalls or doesn't have power when you juice it, it sounds like a fuel problem. It is unlikely a carb issue if it gets regular use and as long as its not sitting for long periods of time.
I would first check the fuel filter. If that's fine, then I would check the vent hole on the gas cap (if you have one). If it is a gravity-fed fuel system and the vent hole on the gas cap is clogged with dirt, dust, and debris, then the gas will not flow to the carb fast enough and you'll get a very lean mixture. Sure, it will idle fine because the engine isn't demanding much fuel at idle, but when you open up the throttle it will stall because the air:fuel ratio will be too high (symptomatic of a lean mixture)
Last thought: Dirty air filter
Let me know if this helps
