Question about RCA RP8070 5-Disc CD Changer
I can't open my player. I apparently pushed too many buttons too fast and confused it. It flashed "error" and now won't do anything other than power up. I tried unplugging it and letting it "rest" overnight, but that didn't help.
  • Denise345 Aug 31, 2009
    I wish it were that simple. But there's no hole anywhere on the unit. :-(
    New Friend:
5 disk changer won't open or close and won't disk skip properly when the buttons were pressed.
Posted on Sep 14, 2011
    New Friend:
I am no expert, but to save someone all the time that I invested with this freezing up issue, will post. Right before it was going to the curb as junk, I unplugged it, reached in with the cover partially off, and forced the circle that holds the cd's to turn an inch or so. Powered it back on, and was back to normal
Posted on Jun 01, 2015
  • 93 Answers
I'll try if I can help!...electromechanical designs must have position sensor or switches to monitor mechanical movements. You've tried to reset by draining but didn't work.If you can open the unit (unplugged) try to find the loading motor usually with belt or worm gear etc. try to rotate until the mechanism reaches the start/ ready position.also check the belt if belt driven.lubrication may also help stacked mechanism.I need votes! that help?
Posted on Sep 01, 2009
  • Robert Conkwright Nov 09, 2012
    Thanks- solution was to remove screw under cabinet.
    Champion:
  • 239 Answers
There should be a small hole near the door, unplug the unit. Get a paper clip and straighten one end and put in the little and gently apply pressure to open the door.
Posted on Aug 31, 2009
  • Mike-Jenkins Aug 31, 2009
    If there's no little hole try to gently pry the drawer open with the power off.
    Thanks- solution was to remove two screws under cabinet.
SOURCE:
Hi I have a panasonic sa-dk10 system been just loving it. But just now I tried to play a DVD and it said there was no disc so I just switched it to another slot and then to the rest because it said the...
Apparently you have to replace STK470-05A power IC.
But even doing that might not fix it.
It seems the problem is very common. Especially if you get an F61 reading.
Jun 08, 2017 | Audio Players & Recorders
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
PS3 won't turn on. When I push the power button
Sounds like your system has a failure in it, that needs professional assistance. If you want your data saved you should try a place called www.videogame911.com. They do fast repairs and can save your data.
Jun 11, 2011 | Sony Video Game Consoles & Games
My tascam mp-gt1 won't recharge - device error
I had the same problem. After trying to turn it on many many times over weeks, I gave up. A few months later I tried it again, and same "Device Error" only. Then I decided to just mess around with it. So I held the power button on with my thumbnail while I pushed all the other buttons. I held in the MENU button for at least five seconds. Held in the ENTER button at least 5 seconds.... multiple buttons. These didn't seem to work, I don't think. but then decided to turn on the power button using the edge of my desk while several fingers pushed multiple other buttons.
To my great shock, all of a sudden, the bloody thing turned on like it's supposed to, logged into a Sugar Ray song I was learning awhile back, apparently. Go figure. After that, it turned on correctly twice so far.
So, heheh, I have no idea what the cure was. Just screw around with holding in multiple buttons while the power is on, I guess.
Aug 12, 2009 | Tascam MP-GT1 MP3 Player
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Rca 53" wont power on, please help
The cicuit board behind the power on and off button needs to be replaced.. good luck everyone
Jan 07, 2009 | RCA D52W19 52" Rear Projection Television
RCA RP8070 5-Disc CD Changer Logo
1,159 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
