Question about HP Broadcom NetXtreme Network Adapter
Network adapter is working but still not getting good connection
When trying to load cable installed CD...getting "connection not present" error message
  • 33 Answers
Make sure the light on your cable modem that represents your connection to the computer (it might be marked LAN, Ethernet, or PC) is lit up and isn't flashing. The light will tell you if your network card is properly connected to the cable modem.
If the light isn't on, make sure you've connected the wire to the right port on the cable modem, and try restarting the cable modem by unplugging it, wait 30 seconds, and plug it back in.
If it still doesn't work after that, contact your Internet provider. Their technical support department can help you get it set up.
Posted on Dec 10, 2007
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Not able to connect to network in dell inspiron 1525
Make sure you got good connection to internet. You can check this by going to network connections and right click on icon and check status.
If not showing connected at top or it is sending and receiving you can try repair adapter by right clicking icon and left click repair. However if the error is at power up it could currupt adapter driver trying to load in witch you would have obtain new driver from manufacturer or a driver agent. If its a system network error you might make sure your system in up to date or the worst thing you might have to do is re-install operating system. There is usually a way to repair system at beginning of install cd. It depends on what operating system you are using.
Oct 24, 2012 | Dell Inspiron E1505 Notebook
Hi i have the canon mp490 all in one printer and i was just wondering how to i get things to print from my lap top
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
Aug 05, 2011 | Computers & Internet
Trying to connect two computers to the internet through a router (not wireless) having problems after connecting both computers to the router, only one computer has internet connection. My internet...
Initially check whether the ip address is assigned in the computer in which internet is not browsing using the command ipconfig/all for windows and ifconfig for linux.If ip is present try to ping the default gateway ip address,if ping is success there is no issue in the cable you used and also with ip address.If ip is not assigned assign ip by manually or by using dhcp of router.Enable and disable the lan card in the router so that sometimes the problem get resolved.After ip is assigned and ping with router is ok .Ensure dns servers are correct else give google public dns server 8.8.8.8.Then try to ping www.google.com in command prompt if ping is success then you can browse.
Mar 01, 2010 | HP Pavilion a1610n PC Desktop
I need a driver for this, lost cd
If you are connecting to the switch using network cable (not usb type), then you don't need software. Just hook up the cable to use it. If your system is not recognizing the switch. then may be you have to install network Lan adapter driver to your network card present in your machine(PC)
I hope this is helpful to you
Thanks
Feb 07, 2010 | D-Link DES 1005 Ethernet Switch
Cannot load ProcNICs.dll error
you can goto start button, run, then type, msconfig
then startup uncheck if its listed ... that will get rid of the error probly if that doesnt work goto control panel add remove programs and uninstall the linksys program and reinstall it from a cd or download the latest version will probly fix the error
Nov 05, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
Cannot connect to network adapter
ask your internet service provider if there is a need for them to configure your modem for a username and password. please also check if the drivers of your network driver is installed to your pc.
Jul 06, 2009 | Belkin (F5D7230-4) Router (587009)
Jukebox nsm2000
Error 60 is connection to the CD player interrupted.
There is no supply voltage present for the decoder board or the CD player.
Check that all of the cables to the decoder board are in good condition and connected correctly and securely.
Jun 14, 2009 | Juniper Networks IDP Upgrade Kit for ISG...
Cannot connect to internet
did you install the drivers cd as well?
Dec 20, 2008 | Motorola Mobility 17235 Network Adapter
802.11b/g adapters
install the driver from the supplied cd and then you will be prompted to connect the adapter, the set up wizard for wireless connection will then be presented when you double click the icon on your desktop
Sep 07, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
HP Broadcom NetXtreme Network Adapter Logo
331 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
