My camera lens is stuck in the closed position. When I turn the camera on, the motor runs, but nothing happens. I accidentally picked the z740 camera when posting the proplem originally, but the z700 is the camera I have.
If you've dropped the camera you may have damaged the lens housing - which will require professional repair, but the problem you describe is frequently due to
corroded battery contacts inside the camera. Remove the batteries and
wipe the camera contacts firmly with a clean cloth (heavy corrosion may
require cleaning with a fine wire brush, steel wool, or fine
sandpaper). Remove any residue that may have fallen into the battery
compartment during cleaning, clean the contacts at both ends of the
batteries, and reinsert them in the camera. This cleaning cures the
problem about 90% of the time, and I hope it works for you.
Hi,my Kodak Easy Share LS743 is not working after turn off power the zoom optical cannot return to...
(More)
Hi,my Kodak Easy Share LS743 is not working after turn off power the zoom optical cannot return to the camera. Thanks
I have pictures on my internal memory. How can i get these pictures from the z700 I only have the...
(More)
I have pictures on my internal memory. How can i get these pictures from the z700 I only have the viedo cable
i can go into favorites but thats it.. i hit power it on it shows the kodak splash screen the lens...
(More)
i can go into favorites but thats it.. i hit power it on it shows the kodak splash screen the lens extends then immediately goes off.
