Question about RCA P61927 61" Rear Projection Television
RCA P61929 picture problem...
I have an RCA P61929 rear-projection tv, and when I power on, it stays on for however long it wants, and turns off. WHEN it turns itself on, it usually has sound, but NO picture. Usually, I will change the input where there is no connection (gray screen), then turn the tv back on and it will work for however long it wants to.. if it wants to. What are my options?
  • Anonymous Jan 31, 2008
    no picture no power rca p61927
  • Judy Mischung Dec 02, 2008
    RCA P61929 - we had a power surge and now it won't turn on - its on a surge protector, I checked the fuse.
  • 3 Answers
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Posted on Dec 02, 2008
I also have a rca p61929, but my problem is that is doesn't have a clear picture. It's blurry and that the screen is double in some areas.
Posted on Jun 27, 2008
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
The picture looks like if it was 3-D, Its not very focus? it is actually for a P61929 Model RCA projection TV screen
Hi:
On this model you must check the micro fuses on the deflection board for open condition, also make sure you check the solder connection on and around the flyback transformer. The unit is out of convergence and usually blows two mini fuses near the end of the board nearest you look at the back.
May 25, 2010 | RCA P52926 52" Rear Projection Television
My RCA model P61929 picture is curved inward on the top and bottom
Is there also a misconvergence? If so you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating!!
hardrocko
Apr 27, 2010 | RCA P50830BL 50" Rear Projection...
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Wont turn on after power outage
there is a power supply board that goes bad in this set. Good luck
Aug 15, 2009 | RCA P61927 61" Rear Projection Television
Will not power on and stay on
Problem is with the IC.Picture tube is OK.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
Help me please
You have bad capacitors 3 of them.cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v
Aug 09, 2008 | RCA D52W19 52" Rear Projection Television
RCA P61927 61" Rear Projection Television Logo
510 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
