Question about Plantronics Explorer 320 Headset
Plantronics ear piece
The ear piece keeps beeping in my ear. How do I stop it, the phone is charged and the ear piece is charged.
  • ybwilliams Jun 19, 2008
  • Al Swilling Jul 04, 2013
    I have also experienced the constant beeping, even when the headset is fully charged. In my case it occurs when I am in a location where the cell phone signal is very weak. For example, when sitting at my desk working on the computer, that area has very weak to no cell phone reception; usually zero bars on the signal meter. At that time, the headset will beep every few seconds, indicating a weak signal. Whenever I move to an area where there is one or more bars on the phone's signal meter, the beeping stops. So, in my case, the beeping is caused by a very weak cell phone signal. The beeping also occurs if my phone is not on my person and I move near or past the maximum range of the headset, which is approximately 30-35 feet. When I'm again within range of the signal, the beeping stops. The solution for each of these scenarios obvious: stay within the head set's range, and try to keep your phone in a spot where it has at least one bar on the signal strength meter.
I need a passcode for my bluetooth so i can put it on my blackjack
Posted on Feb 29, 2008
My plantronic bluetooth not connecting.
1. You have to keep the on/off button on plantronic pressed for almost 1 min.
2. You will see the blue and red light flashing on it repeatedly and then try to locate the handsfree on your mobile handset;
3. Now you will be able to see the bluetooth on your mobile and then you will be able to connect it throught;
4. In case it asks for a password enter 0000.
5. Once connected you will hear a beep in your ear; this confirms connection;
6. Ensure your bluetooth handsfree is charged properly.
Try and rank me if you succeed.
Jun 09, 2011 | LG Cell Phones
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
It will not turn on after a full charge
Sounds like you have a bum unit.  Plantronics gives a 1 year warranty with every wireless product, I'd send it back.
Have you made sure that you're turning it on correctly?  You push the call answer button and hold it down for about 3 - 5 seconds before it turns on, until the blue light turns on.  Make sure that you don't hold it longer than that or it will go into pairing mode.
Apr 26, 2009 | Plantronics Discovery 925 Bluetooth...
Can not get my plantronics calisto phone to par with the headset or the base
We have two of the Calistro Pros and they will lose contact all the time for no apparent reason. Most of the time when I walk to far away from the handset they will beep and there will be the "OUT OF RANGE" will display. I have found that while sitting next to the phone press the ear piece switch straight in. You will hear a series of tones either getting louder or going from high to low. Wait a few seconds after pressing the ear piece switch and then look at the hand set. the No Headset circle should dissaper. If not depress the earpiece switch and listing for the tones again. Wait again and they will find each other. If this does not help you then I think you have a phone issue. I use my for 8 hours a day and have to do this several times a day. I hope this helps.
Apr 09, 2009 | Plantronics Calisto Pro Series Cordless...
How do i connect phone with m2300 ear piece
Begin with Headset turned off. Press button for 6 sec. Release button when Light Indicator flashes blue and red. Headset is ready to pair with Bluetooth device. Use your device?s menu to enter pairing mode and select ?320 Plantronics? on the display. When asked for passkey, enter ?0000.?
Mar 28, 2009 | Plantronics Explorer 320 Wireless Headset
No beeping in ear piece
The microphone in the lifter was not centered over the microphone on my phone, so all I did was centered the lifter over the microphone, and it works.
Mar 18, 2009 | Plantronics PL-CS55 Wireless Headset
Connect pantronics 320 to Iphone
I have a 300 series Plantronics and it only functions if I unpair and repair with the I phone each time I want it to work. The AT & T technician tells me that the one I have has old software in it and that is all it will ever do. It also does not "beep" in the ear when it connects like it did when I had it paired to my Motorola L7. That makes it hard to know if it is connected even though the I phone says it is paired with the Plantronics ear piece even if the ear piece is turned off.
Jan 12, 2009 | Plantronics Explorer 320 Wireless Headset
Plantronics Explorer Plantronics Explorer
That is the job of the ear piece to keep the device in the ear
Jun 19, 2008 | Plantronics Explorer 320 Headset
Plantronics Explorer 320 Headset Logo
450 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
