Question about Microwave Ovens
Kenmore microwave shuts off after several seconds
Problem is two fold. Our Kenmore microwave model # 721.80592 fan started running for extended periods, when not in use. Problem seemed to arise when water was boiled on stove below. Initially this seemed to be solved by pulling plug. Problem has now morphed into microwave shutting off after several seconds. Thermostat was replaced with no effect. Your help is greatly appreciated.
TS
  • 2rbk Dec 11, 2007
    Thanks for feedback. Full model number is
    721.80592402
  • Microwave Ovens Master
  • 9,098 Answers
Hopefully the hood / vent fan was always on when boiling on the stove top.
Otherwise moisture can get into and damage the keypad or control circuit board.
That may be the problem.
If this is a convection model, it may have a bad thermistor (not to be confused with a thermostat).
The full model has three more digits, in case you need more help and want to post that.
If you or a friend decide to look into it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find an exploded view by entering your full model number here: http://www3.sears.com (the 3 is correct)
Posted on Dec 07, 2007
I have a microwave model # R-308NW. When I press
if when it shuts off clock resets to first plugged in state, sounds as if control panel is being reset by something (failure of part, or power surge) if clock is still ok and maintains correct time , I'll bet if you notice the cooliing fan is not running correctly (by sound it makes) in those two seconds, this will over heat magnetron and shut off on thermal hi temp (safety) if so fan will need to be serviced by a professional
Sep 10, 2014 | Microwave Ovens
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Ge pvm2070smss shuts down
It may be a noisy magnetron if the failure occurs in a second or two of hitting "Start" to begin cooking.
See this FixYa solution. even though your model number is different.
Otherwise, if the internal cooling fan is not running when you are cooking, it will shut down after 30-60 seconds or so and stay off until it cools back down.
Also see http://www.microwavedisplay.com/jvm2070.htm
Feb 24, 2013 | GE PVM2070SMSS Microwave Oven
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Apr 25, 2009 | Kenmore Microwave Ovens
Microwave hood # 721.80833500
One of 2 things are happening..One of the thermo protectors has a bad connection (Kenmore is good for these) or the Magnetron has a leak inside the control cavity causing a temporary short in the control.
Dec 30, 2008 | Kenmore 80809 Microwave Oven
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Shuts down after running about 8-9 seconds.
We'd need the full model number to be sure, but it sounds like an inverter failure. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. I would call Sears for service. See http://www.sears.com
Sep 15, 2007 | Kenmore 80883 Microwave Oven
Microwave Ovens Logo
337 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
