Question about Plantronics Explorer 320 Headset
Plantronics Beeping When in Use
I just got this thing and it set up really easy, but now it beeps, my phone is charged and the ear piece is also charged. The ear piece beeps and it is driving me crazy. Is this how is is suppose to work? How do I stop the ear piece from beeping!
  • Anndy Dec 06, 2007
    Not sure why I need to add another comment.
3 Suggested Answers
SOURCE: plantronics ear piece
i need a passcode for my bluetooth so i can put it on my blackjack
Posted on Feb 29, 2008
SOURCE: No beeping in ear piece
The microphone in the lifter was not centered over the microphone on my phone, so all I did was centered the lifter over the microphone, and it works.
Posted on Mar 19, 2009
8xx plantronics blue tooth will not stop beeping after a call. i powered off the blue tooth and beeps stops but returns after the first call
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Good luck from Headsets Direct!
Apr 23, 2011 | Plantronics Voyager 835 Bluetooth Headset
There is a constant beebing in my ear every 3/4 seconds and sometimes my customer can here this too How can i stop this???
Usually, that's an indication that the battery is dying. You need to recharge it. If the headpiece is not holding a charge anymore, you need to replace the battery. Model of battery is CPP-512Q. If the unit is fairly new, you can try reseting the battery by taking off the cap on the headset and then unplug the battery and plug it back in. Good luck.
Mar 03, 2011 | Plantronics CS60 Professional Headset
Can not get my plantronics calisto phone to par with the headset or the base
We have two of the Calistro Pros and they will lose contact all the time for no apparent reason. Most of the time when I walk to far away from the handset they will beep and there will be the "OUT OF RANGE" will display. I have found that while sitting next to the phone press the ear piece switch straight in. You will hear a series of tones either getting louder or going from high to low. Wait a few seconds after pressing the ear piece switch and then look at the hand set. the No Headset circle should dissaper. If not depress the earpiece switch and listing for the tones again. Wait again and they will find each other. If this does not help you then I think you have a phone issue. I use my for 8 hours a day and have to do this several times a day. I hope this helps.
Apr 09, 2009 | Plantronics Calisto Pro Series Cordless...
How do i connect phone with m2300 ear piece
Begin with Headset turned off. Press button for 6 sec. Release button when Light Indicator flashes blue and red. Headset is ready to pair with Bluetooth device. Use your device?s menu to enter pairing mode and select ?320 Plantronics? on the display. When asked for passkey, enter ?0000.?
Mar 28, 2009 | Plantronics Explorer 320 Wireless Headset
Mar 18, 2009 | Plantronics PL-CS55 Wireless Headset
Connect pantronics 320 to Iphone
I have a 300 series Plantronics and it only functions if I unpair and repair with the I phone each time I want it to work. The AT & T technician tells me that the one I have has old software in it and that is all it will ever do. It also does not "beep" in the ear when it connects like it did when I had it paired to my Motorola L7. That makes it hard to know if it is connected even though the I phone says it is paired with the Plantronics ear piece even if the ear piece is turned off.
Jan 12, 2009 | Plantronics Explorer 320 Wireless Headset
Plantronics Explorer Plantronics Explorer
That is the job of the ear piece to keep the device in the ear
Jun 19, 2008 | Plantronics Explorer 320 Headset
Dec 06, 2007 | Plantronics Explorer 320 Headset
Plantronics Explorer 320 Headset Logo
360 people viewed this question
Top Plantronics Radio Communications Experts
skiffy99
skiffy99
Level 1 Expert
shaun taylor
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
