Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Circuit Board I made a mistake when I was mounting my Protron PLTV26 on the brackett, by drilling through the circuit board and now I am trying to find out where I can get a new one. Any suggestings?
I HAVE AN EXTRA CIRCUIT BOARD LET ME KNOW IF YOU NEED IT.
Posted on Jun 14, 2008
    President:
  • 4,402 Answers
If you didn't damage it to bad you could take a wire and use it as a jumper to cross over the traces you drill thru.
Posted on Dec 06, 2007
My Klipsch cs 500 has no sound. Blue light is on and I have tried every combination on remote to no avail. Any ideas?
There is the panel mounted 4amp fuse, and then there is a circuit mounted 6amp inline fuse as well. Mine blew due to a power surge that blew up other things in my house as well. It’s a bear to get the circuit board screws off, and some green sealant off! Step 1) I’m ordering a panel mounted fuse holder that is the same style as the 4amp fuse holder. Step 2) drill hole in panel, and install fuse holder Step 3) no need to remove old fuse (since its blown) so I’m soldering wires from new fuse holder to the fuse ends on the circuit board
Oct 29, 2017 | Klipsch Audio Players & Recorders
Tip
Dryer operates but will not heat.
1. Disconnect electrical power to dryer.
2. Remove the lid.
3.On the front panel there is a circuit board (moisture sensor control board) with a six pin connector. Disconnect the connector
4. Remove the circuit board from mounting bracket by pushing either the upper or lower lip of the mount bracket.
5.Clean the backside (solder side) of circuit board. I used a toothbrush. 6.Install the circuit board and reconnect wire harness.
on Dec 06, 2008 | Frigidaire GLEQ642A Electric Dryer
How to reapair faulty headphone socket?
Check if wires are loose on it, Or if solder is bad on circuit board. Where the head phone jack Mounts onto circuit board. If wires are loose, Solder them , The same goes if it is mounted on the circuit board, Check for bad solder connection,
Sep 03, 2014 | Audio Players & Recorders
C7 36 volt charger not working keeps blowing internal fuse
If the fuse is blowing before the battery is installed to charge, the problem lies on the circuit board. Since it is most likely a switch mode supply, you might try replacing the electrolytic capacitors first. Then check what should be a MOSFET, although some may have a regular bipolar transistor as well.
If the charger blows the fuse when the battery is installed for charging, the battery has some shorted cells that overloading the charger, or the contacts are distorted and being shorted by the battery
Feb 17, 2012 | Drills
We have 3 Protron PLTV26 TV's Model LT26C1P1 I am
RCA, and several other companies, make all in one remotes. If you check their websites, you'll find lists of the TV's they'll control, along with the programming control codes (the codes are included in a booklet in the package with the new remotes).
Looking at the RCA site, and the sites of several others, they all seem to have the control codes for Proton.
Jul 06, 2011 | Televison & Video
No reverse on drill.
I am assuming the new switch was wired correctly, I would look for the pin or similar device that switches it from for/rev. If your switch has a post look at the slider and make sure not broke or your pin not put in rightt position. Let me know
Apr 22, 2010 | Black & Decker Drills
Where can I obtain a circuit board for a bosch cordless drill charger, Charger is AL 2404, part number 2 607 255 185, also has D-70745 Leinfelden printed on charger
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Jan 13, 2010 | Bosch Drills
Sharp LC-32D40U shows no video few seconds after turning it ON
Modification of the inverter unit usually takes care of this problem.
Jun 02, 2009 | Sharp LC-32D40U 32 in. HDTV LCD TV
One more question
The electronic control board will have to be replaced. You can search online or call Sears (they can order just about any type of part for any type of product for you) with a model and serial number. Generally, the electronic control board is not that difficult to replace.
Jun 09, 2008 | Ovens
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
57 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
