Question about SanDisk Sansa c240 MP3 Player
How do you OPEN the battery compartment of this mp3?
I can't seem to get it open at all. It says to press the tab on the battery compartment of the back. There is no protruding "tab" and I press the flat "tab" but nothing happens. I just can't seem to open it.
PLEASE HELP!
Thanks,
~Susan
  • sae1991 Dec 07, 2007
    I eventually figured it out. Many thanks!
  • TvEx Dec 23, 2007
    I've tried pulling the tab, and pushing up and pulling down.
    Any help?
    Problem Solver:
  • 7 Answers
Its pretty actually. Just push down, (like the safety cover on a prescription bottle) and push it outward. You may have to you use as much force to get it open. hope i helped. 8-D
Posted on Jan 04, 2008
How do I fix a jammed battery compartment in a kidde i12060 smoke detector?
You could try to pry the door loose with a small screwdriver. To be safe, make sure the primary 110V power is turned off before trying to loosen the compartment door.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door open.
If you do decide to replace it, you may want to look into a combination unit which monitors smoke and carbon monoxide if you don't have a carbon monoxide detector already in your home.
Aug 26, 2015 | Kidde i12060 Hardwire w/ Front Load...
I want to split open my freeview topuptv remote,enabling me to get at the right right green arrow button mocro switch.
I don't have Freeview, but often on remotes there is a screw hiding in the battery compartment. Then prise open gently to see where the plastic tabs are that hold the two halves together. Push and twist with a broad blade screwdriver at these tabs.
Nov 02, 2013 | Televison & Video
How to open battery compartment on remote
That clear plastic tab was there simply to keep the battery from making contact and running down.Since you declined to specify a make or model I can't give you definitive instructions. Can you find the outline of the battery cover? There's probably a set of grooved ribs on the cover, possibly with an arrow. If there is an arrow, put your thumb on the ribs and push in that direction. If there isn't an arrow you may have to try both directions if it's not obvious which way it's supposed to go.If you need further assistance feel free to reply to this post, but also be sure to specify the make and model of whatever device you're trying to open.
Apr 22, 2012 | Audio Players & Recorders
Proform gr 80 recumbent exercise bike cant get the display to turn off when I get off bike. battery powered?
The GR80 uses for type D batteries. The battery compartment is on the bottom of the console, look for the D-shaped battery door, press the tab located towards the front side of the console and open the door. Careful, the batteries may fall down if you open the door - type Ds are heavy enough to be felt when they fall on your feet.
Jan 16, 2011 | Proform GT 85 x Upright Bike at GNC
How do you open battery slot
(1)Remove the USB connector cover.
(2)Press and Move the battery cover in the direction of the arrow.
(3)Remove the battery cover and insert one AAA-size battery into the
(4)Replace the battery cover.
Jan 23, 2010 | Nextar MA933A MP3 Player
1998 LeSabre center storage console doesn't open
Place the palm of your hand on the top and curl your fingers under the lip and press upward toward your palm,it should then open.When open you can fold the cup holder inside the console.
Dec 20, 2009 | 1998 Buick LeSabre
How do I download music from a folder on my computer. Everytime I try it shows "empty disc" when I press music ????? Frustrated
are you trying to download to your mp3 player?if yes then connect mp3 player to pc open my computer tab find your mp3 player there open mp3 player tab then drag and click your music to the mp3 player
Aug 15, 2009 | Nextar MA933A MP3 Player
Remotes don't seem to register with gaming system
Before Pressing the Red Button inside the Battery Compartment. Make sure to open the Small "Door" on the Front of the Wii and press the Small Red "Sync" Button first and then Press the Small Red Button inside the Battery Compartment. You should hear a "beep" to confirm that your Wii Remote has been reconnected.
I hope this helps. Take care =)
Dec 08, 2008 | Nintendo Wii Console
Wont stay turned on.
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GoGear SA178 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
