Take your battery out and look for either a pea sized white or red circle....this is the moisture indicator...If it is white than your phone did not get wet. If it is red then it has gotten wet and you might have to buy a new one if the drying out doesnt work.....check if you have any replacement warranty stuff on your plan.
Take the battery out and let all of the components inside the cell phone dry out, then try powering it up, never power up a wet phone this will certainly cause damage to it. I had mine go through the washer (believe it or not!) and I let it dry out for several days and it worked fine afterwards. Good luck to you!
