Casio CFX 9850GB Plus Calculator
Problem for Casio CFX 9850GB Plus Calculator
My casio calculator cfx is coming up with 'syn
By dangerous_wh on Aug 31, 2009
my casio calculator cfx is coming up with 'syn error' everytime I type in a sine cosin or tangent problem
Best Solution
posted on Sep 21, 2009
Very Helpful)
k24674
Rank: Guru  Casio Office Equipment  Expert
Rating: 87%, 679 votes
I believe you are not pressing the keys in the right order.
If you know how to set angle unit, skip this part and go to Exemples
If you want to calculate the sine , cosine or tangent of an angle given in degrees, the calculator must have the angle unit set to degrees. To do so :Turn calculator ON, scroll to [RUN] icon and press [EXE] then [SHIFT][SETUP]. On the fifth line angle must be set Degrees. If it is not in degrees, press the key correspondig to menu deg (F1)
(If you have to use the Radian as unit of angle, that is where you set it.)
So your angle is in degrees.
Exemples
To calculate the sine of 15 degrees press [SIN] 15 [EXE].
If expression inside the sine is complicated or contains diverse operations use parentheses as in the exemple
[SIN] [(] 90/2 -180/3 [)] [EXE].
You proceed the same way for cosine, or tangent.
Hope it helps.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Casio CFX 9850GB Plus
Questions and Unsolved Problems for Casio CFX 9850GB Plus
Do you recommend Casio CFX 9850GB Plus Calculator?
Answer
Answer
i need new display for my casio gfx-9850gb plus
Answer
How do you do standard error of the estimate?
Answer
How do I graph a function from the y-list and data from a list on the same graph?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio CFX 9850GB Plus...:
Top Calculator Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
