Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Blinking blue light and no display
We have had power failures the past few days due to wind and snow. Every time the power fails the moniter will not turn back on when I turn the computer back on. Only the blue light flashes indicating powersaver mode. I have rebooted the computer, unplugged all cords and pressed severad buttons, menu and others but it will not come back. I have the Synchmaster 204b. Please help.
Thankyou!
gpdj3k@hughes.net
  • Anonymous Dec 07, 2007
    help
    Genius:
  • 1,003 Answers
I WOULD REMOVE REAR PANEL AND LOOK FOR A MASTER RESET BUTTON OR A BLOWN FUSE ALSO CHCEK
YOU AC ADAPTOR TO SEE IF IT IS WORKING FIRST.
Posted on Jan 16, 2008
My Gigabyte GA 945GM S2 Mother Board Staring & Turning Off After Few Seconds. At start time CPU Fan starts with a blinking. Whats the Problem?
several possible problems just do process of elimination possible failing processor or power supply or memory failure good luck
Mar 31, 2013 | Gigabyte Computers & Internet
Hello here is the gigabyte homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2331&dl=1#manual
Try to download the manual.
The fault could be the power supply, try to renew that.
Try also to renew the thermal paste, between the cooling element and the cpu, and make sure the fan and the cooling element is clean for dust.
The fault could also be a defect ram module.
Any beep codes ???
Or blue screen ???
Good luck
Mar 31, 2013 | Computers & Internet
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
1,215 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
