I've double wall ovens. The top oven won't reach heat setting. I noticed the lower element doesn't get warm at all, but the hot ones seems to be acting normal. I removed the element and put it in the other oven and it works fine. So the element is fine. Is it a wiring issue?
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Thank you for the info. The model # is PLEB30T8CCB
