Question about Brother MFC-8860DN Printer
Scanning I need to figure out a way to scan large documents with a high enough dpi to be legible but not have them end up over 10MB so that I can attach them to e-mail. The only way I have found to keep the size down is to decrease the quality, which doesn't work well for the recipient. I have a Brother MFC-8860DN networked into my computer. Any suggestions???
One approach that works for me is to scan the document at high resolution and then shrink it afterwards. For some reason this seems to result in higher quality than scanning at the final (lower) resolution in many cases. For example I use ACDSee Photo Manager to scan or post process a scan from elsewhere. Within ACDSee there is an option in the jpg output (file save as) dialog for quality versus compression. I set this to default to the highest compression and resave the jpg or convert to jpg if the file did not start out that way. This generally shrinks the file by up to 2x or even 4x without any degradation that I can see. For example the screen capture below went from 39k to 18k after this step with no resolution change. If that is not enough I then perform a resize operation, for example 50% which would further reduce the file size down to a quarter of the input size (the dimensions in each direction would shrink by 50%. Even after shrinking, I find that files lookbetter than if they had simply been scanned at the final resolution.Scanning - f611aa5.jpg
Posted on Jun 28, 2008
Tip
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
How do I reduce file size for scanned documents?
You're probably scanning at a high DPI or resolution. Try scanning at a lower DPI or shrinking the actual dimensions of the image in an image editing program.
File format is important also. .jpg files are compressed and take up far less space than .bmp files, for instance.
Sep 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
S. Mohan, Chennai, India
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
Please help... when i scan more than 10 docs and then try to attach it to an email, it states that the file is too large ... please help me with my Lexmark X4270
You should setup the scan resolution to a lot less.
Scanned images can take a lot of space it scanned at high resolution and with many colors.
If it is a document, you can set it to scan black and white or gray and instead of the default resolution (300dpi) you should try scanning at 75dpi or 100dpi.
Those settings can reduce a scanned image to few ks instead of 10s of megs.
The average mail systems can't handle mail messages larger than 10Mb.
I would also suggest playing with the scanner to get the best results before trying to mail the scanned documents.
Nov 10, 2010 | Lexmark All-in-One Printer with PictBridge
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Scanning in colour
Who and where do you get the idea that you should be able to, to scan in colour you need a colour scanner, yours is not it has a greyscale scanner only.
This machine has a scanning kit option but that is not colour see specs below.
AR-NS2 Network Scanning Kit (optional) 4
Type:
Flat bed monochrome scanning system
Original Feed System: Platen/document feeder, simplex/duplex with RSPF feeds up to 39 opm
Resolution:
200 dpi, 300 dpi, 600 dpi
Image Format:
TIFF 6.0, ITU-T G3/G4 TIFF, G3/G4 single/multi-page PDF
Scan Destinations:
E-mail, Desktop, FTP, URL
Destination Profiles:
Up to 200
Operating System:
Windows 95/98/ME, 2000, XP
Network Protocols:
TCP/IP (includes SMTP, LDAP, FTP)
Network Security:
E-mail server user authentication
Software:
Sharpdesk Document Management Software (included)
Link to brochere of the AR-M 237 GREYSCALE copier
Jan 10, 2008 | Sharp AR-M237 Copier
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Brother MFC-8860DN Printer Logo
146 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
