Question about Sony Xplode P5 Turbo Subwoofers Car Speaker
Subwoofer power but no sound
Sony subwoofer model # sawmsp1. There is power to the system but no out put of sound. is it worth taking in to reapir.
    New Friend:
  • 101 Answers
Sony suks.is it a powered sud?if not take any battery and touch the leads on the speaker if u get a sound speaker is workig.
Posted on Jan 23, 2008
Sony sa-wmsp1. My grandson put lego pieces in my subwoofer. How do I get them out?
By the looks of it, I think you are going to have to disassemble the speaker and manually remove the lego pieces. (Aren't grandkids fun? I can't turn my back on my mine, he's a little tornado!)
Here's a copy of the manual in PDF, all you have to do is remove some screws (they are identified as "SCREW +BVTP 4X10 TYPE2 N-S" (# 57 on the diagram on page 6) so I'm guessing that they are Torx.
https://data2.manualslib.com/pdf4/98/9728/972764-sony/sawmsp1.pdf?a8af4853f66111cc942c1766abc50b79
After you get the back off, you may also have to remove the front cover (screws are accessed from the inside) Not a hard fix overall, should take a hour or less.
Feb 09, 2018 | Sony Audio Players & Recorders
I have a proton satria 2007 model with a fully intergarted head u
First off, change the front speakers with a decent pair of aftermarket. Buy a powered subwoofer. One that has the amp built in. Connect it to the rear speakers. Bazooka tubes are great, compact, great bass.Adjust your radio so that the front speakers do not recieve alot of bass,you want it about half way. That way you are using all the power to push high notes, Bass takes a lot of power to push, reducing the volume. Turn the subwoofer to the maximum setting, and then adjust the system to your liking. It will take some time, but it is worth it in the end. Tip: set it while listening to your favorite station. Stations broadcast at different sound levels. Some pump up the bass, some don't.
Apr 15, 2010 | Car Audio & Video
Power turns(light) but no sound. Fuses all good??
apparently there is are some components on the main board that need replacing:
This is usually what needs to be replaced on these subs.
Replace
R830
R831-4.7 ohm 5% 1/4w fusible
C860 - 082 mf 5% 50v
Direct from Sony:
hxxp://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
c860 is Part # 113616400 $2.14
r830 is Part # 121284900 $2.14
Jan 22, 2010 | Sony SA-WX700 Subwoofer
Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms position...you will put a lead on each of the terminals of the speaker...you should have a reading of 2, 4, 8 ohms....you may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Aug 09, 2009 | Sony SA-WM500 Subwoofer
No sound from Sony SA2500 subwoofer
Please intimate exact model number written on sticker pasted at back of Sony subwoofer to provide you help.
Aug 01, 2009 | Sony SA-WX700 Subwoofer
What voltage required to power a sony subwoofer
Hey,
I just got one of these units, the SONY SS-WG990.
The RCA cable is direct conection to the speaker.
It requires external AMP.
The other cable is just for the system switch and LED.
If you just have this unit, all you need is an AMP to
feed it.
Apr 12, 2008 | Audio Players & Recorders
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
No sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Oct 25, 2007 | Sony STR-DG510 Receiver
Car Audio & Video Logo
182 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
