Question about Achiever CCS-1500 Cross-Cut Shredder
Achiever Shredder CC5-1500
The litle red light stay on, can not get it to go off
    Scholar:
  • 102 Answers
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pcAchiever Shredder CC5-1500 - 1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
Fix this shredder
The unit is probably clogged up with a bunch of shredded paper. Unplug it ! Clean out the paper using fingers and a knife to get most of the paper clips and paper out then plug it in and run forward and reverse. That's what i do and it works every time.
Nov 16, 2013 | Achiever CCS-1500 Cross-Cut Shredder
Where can you purchase repair parts? the teeth are stripped on one of the gears. I need a replacement gear for my Achiever SCS-6 Shredder.
I appreciate your intent to help solve my printer problem. However, I do not think it should require me to pay a fee to get an address to locate a Company to obtain a replacement part for my Achiever shredder.
Oct 02, 2009 | Achiever SCS-6 Strip-Cut Shredder
GREEN POWER LIGHT ON RED LIGHT BLINKING MACHINE WILL NOT GO IN FORWARD OR BACKWARD
Common reasons for this is dirty or blocked sensors on top and under the cutter asm.Also, the waste basket door sensor or switch is activated.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 03, 2009 | Achiever CCS-1500 Cross-Cut Shredder
Squealing Shredder
you need to spray lubricant down the paper shout. the cutter wheels are dry. They make a shredder oil but you don't need that just a light what oil. wd40 is to heave. If the noise is still there then it is in the gear train and will need to br serviced.
but to much oil will make a build up of dust also it's a catchy 22
Nov 03, 2008 | Achiever CCS5000 Shredder
I need a manual for my shredder
the overload beeper want cut off and there no paper in it
Aug 27, 2008 | Achiever CCS5000 Shredder
Achiever shredder
The fuse has blown and we need a new fuse for it. We need the fuse number that is on the tip of the fuse. Do you know where we are able to purchase them from?
Jun 10, 2008 | Achiever CCS5000 Shredder
Achiever Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 02, 2007 | Achiever CCS-1500 Cross-Cut Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
Achiever CCS-1500 Cross-Cut Shredder Logo
129 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Marvin
Marvin
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
