I have an older amana fridge with freezer on the bottom. It sat for awhile. Now when I run it the condencer and freezer work fine but the fan that blows up to the fridge compartment seems sticky. i wound it around a litttle and it started running. however when the fridge gets to temp and it stops it won't start again. Is it toast? any ideas so i don't have to buy a 135 dollar fan?
I would first suspect that the fan motor shaft just has gunk on it keeping it from starting -- clean & lubricate both ends of the motor.
If this doesn't solve the problem, it's the motor start capacitor -- could be inside the motor housing or could be outboard, connected to it via the wiring harness. A capacitor is a lot cheaper than a fan...
Charlie
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Definitely gave me some direction not found in the owners manual!
" - terrence_tol
Popular Solutions for Amana ASD2625KE Side by Side
I changed the water filter ran several pitchers of water as directed. The filter ok light does not...
(More)
I changed the water filter ran several pitchers of water as directed. The filter ok light does not light. Is this a problem? I pressed the water & lock buttons as directed but the ok light still doesn't light. The larger green light above the filter indicators is light.
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new...
(More)
My Amana side-by-side fridge (model SZD26VW) stopped getting cold about 10 days ago, I bought it new 9 years ago. After checking my owners manual I decided it needed a good cleaning, so i took all food out, pull it out from wall, cleaned the condenser coils (lots of dirt) cleaned the condenser fan (lots of dirt)unplugged and open both doors for 24 hours,, started it back up and it worked great for 12 hours-got cold- made ice- cold water from dispenser... then it stopped (no cold air) no water coming out of dispenser,, turned off for 4 hours and then started it back up,,, worked great for about 12 hours and then stopped again, HELP any ideas?
I took it out to fix it because the bar that turns the ice came off. The front assembly with the...
(More)
I took it out to fix it because the bar that turns the ice came off. The front assembly with the blades came apart and I dont know how it goes back together.
