Single horizontal line in middle of screen
I have a 15 year old Mitsubishi CS-35403. For a while now it was showing white lines along the top of the screen. I figured the CRT was starting to go. This morning all I got was a single horizontal line in the middle of the screen. If it is the picture tube (CRT) I really don't think it's worth the $ to fix. I could probably buy a brand new HD for the same money. Any ideas?
    Problem Solver:
  • 16 Answers
Yeah, thats the tube, buy a new one. It's 15 yo anyway, let it go ;) Best of luck!!
Posted on Aug 31, 2009
Testimonial: "I feel that this person gave me good advice and reinforced my decision to let this 15 year old TV go."
SOURCE:
White horizontal line middle screen
That means you blew your vertical output transistor. This likely happened because some electrolytic capacitors dried up and nneded replacing.
Nov 26, 2013 | Mitsubishi CS-35505 35" TV
Actually the model is cs-313050. its quite old. the problem is that the tv won't work in the way that when you turn it on (it won't even turn on anymore) there is nothing but a white or blue lineright in...
you didn't mentioned if it is a horizontal line but i think it is.
It seems that you have a faulty vertical I.C. that scan vertical line.Because you it is defective you've lost the vertical scanning thats why you have only a horizontal line on the screen.
You will confirm it by powering on the unit with your cable signal present.When the sound is present on every channel it is confirm that you have a problem on the vertical section. You must look for a qualified technician to solve the problem....
Jan 02, 2011 | Mitsubishi CS-40503 TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
no picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
May 18, 2009 | Mitsubishi CS-40503 TV
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Mitsubishi cs27403c tv problem
kindly...see first the flyback and adjust the screen if the horizontal line still there adjust the fucos....
Jan 08, 2008 | Mitsubishi CS-27405 TV
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Ekse
