Question about LG VX5300 Cellular Phone
Car Kit mode on
I just was charging my cell and when i unpluged it car kit mode was on. I tryed to remove it but unsuccessfuly
  • cassie roth Dec 19, 2007
    my phone had gotten wet, al little water had spilled on it, and it was fine at first but about 20 mins later it was on car kit, ive turnd the bluettooth off, i took the battery out n dried it and dried out the phone as well, i need this phone to work and it willl be awhile b4 i can take it to the store. the sooner i can disable the car kit the better off ill be, if you could help me out it would realy be great, i dont know what else to do
Have you used the start up mode on your phone? Take out the sim card and restart the phone on off line mode then close and when you turn on your phone with sim card restart in general mode.
Posted on Dec 06, 2007
Stuck on car kit mode
I tried just taking out the battery, turning it off and on, and screwing with the settings. I took the battery out and a ran a mental fingernail file across the top and bottom of the pins where normally charge the phone from. I put the battery back in and it was out of car kit mode. It is working fine now! You can try this too.
Feb 15, 2011 | LG VX8300 Cellular Phone
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
LG "car kit" switch
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. From the indication you are giving sounds like some moisture got in the phone via the charge port, you can try taking phone and battery apart and let sit overnight or put in bowl of rice to remove moisture
May 20, 2010 | LG VX8300 Cellular Phone
Phone says
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. There is no specific setting to turn on or off 'car kit' mode
Mar 25, 2010 | LG VX8300 Cellular Phone
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Also this can happen due to shortening of the 2 power pins at the bottom. Try using an alluminium piece cone shaped and toggle the pins. They will come out. Car Kit mode comes sometimes due to moisture in the power pins, shortening it.
Sep 18, 2009 | LG VX3400 Cellular Phone
Car kit mode
Feb 17, 2008 | LG VX8300 Cellular Phone
Car kit
You don't mentioned your cell type and model. You will get the solution definetly but before that I have to know that.
Jan 08, 2008 | Cell Phones
Verizon lg vx3300
intead of puting foil in it just stick you jack back into the phone and wiggle it a lot. It works trust me =)
Oct 21, 2007 | Nokia 1100
Car kit mode???
The Car Kit message is usually caused by corrosion in your charging port. Yes, holding * may revive the phone, but your best bet is to get some contact cleaner and a toothbrush and clean out your charging port.
Sep 25, 2007 | LG VX8300 Cellular Phone
LG VX5300 Cellular Phone Logo
243 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
