Sharp AF-S85FX Thru-Wall/Window Air Conditioner
Problem for Sharp AF-S85FX Thru-Wall/Window Air Conditioner
Ei flashing display unit power cutoff
By scott4la on Aug 31, 2009
my AF-S85FX unit shuts off after 15 min and the display reads; "EI"'
Solution #1
posted on Aug 31, 2009
Not Rated)
A_HVAC
Rank: Wiz
Rating: 85%, 45 votes
E1 MEANS FILTER CLEAN AND THEN CHECK IF STILL ON THIS IS ASOFTWARE PROB CAN BE DONE ONLY BY THE SEALER SUPPORT.
Was this helpful?
Yes
No
Popular Solutions for Sharp AF-S85FX
Questions and Unsolved Problems for Sharp AF-S85FX
Do you recommend Sharp AF-S85FX Thru-Wall/Window Air Conditioner?
Answer
Answer
Climate won't change from hot cold ?
Answer
I've tried the "hold on to power button while resetting" methods (and similar variations).... (More)
Answer
My window unit cuts off and displays E1 flashing. I have unplugged the unit, cleaned the filter and... (More)
Answer
I have a sharp window unit that has worked for the last 4 years or so. I was installing it this... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
