i have a ati radeon grafix card 9550/x1050 have my monitor pluged into the vga port and tv pluged into s video port the problem i have is when i turn on pc during boot up i get a message on the monitor signal out of range. the tv however is fine.when the os has loaded displays are both fine. if i unplug s video lead the monitor displays boot up.but they both used to work together. i have recently put windows7 on a seperate drive dual boot with xp on the other drive. i am prity sure i had this problem on the morning of this new settup. i have also tried updating drivers for the grafix card.
Comments:
Sep 07, 2009
- thanks tried that for both os is there a way to reset the card by any chance as said this only happens on boot up and is ok if i remove the s video lead
Try to check the screen resolution and the screen refresh rate. Try to set it first to 60hz for the screen refresh rate and try to set the screen resolution to 1024 x 768.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for ATI RADEON HD 2400 PRO Graphic
When my ATI drivers are installed on my computer to get HD signal the color Red stops coming up....
(More)
When my ATI drivers are installed on my computer to get HD signal the color Red stops coming up. When the ATI drivers are uninstalled the VGA signal works and all the colors come through but no longer get HD signal to monitor. Have downloaded all the updateds for both the Acer Flat Panel monitor. And the latest updates to the Raedon X4350 that i just purchased a week ago.
nie mogä? zainstalowaä? programu do karty graficznej ATI his radeon 9550 brakuje...
(More)
nie mogä? zainstalowaä? programu do karty graficznej ATI his radeon 9550 brakuje mi VGA card
I have the exact same problem as yours. I tried to so many solution, it does work sometime. I tried...
(More)
I have the exact same problem as yours. I tried to so many solution, it does work sometime. I tried to plug in the default VGA cable to the on board graphic, it works perfectly. But when I swap back to the Radeon 2400 from the DVI cable, it happens again sometimes. I would like to resolve this problem, it is so frustrating.
ati radeon 4670 video card is stating issues with sketchup pro 7. What issues is the software having...
(More)
ati radeon 4670 video card is stating issues with sketchup pro 7. What issues is the software having with this graphics card and can it be fixed. This is the best video card that this studio xps 16 has.
