Question about Microsoft Windows 98 for PC
Broad Band internet connection under WINDOWS 98SE.
Can not activate network setup wizard under WINDOWS 98SE
  • 45 Answers
I think it is because 98se is not compatible with broadband or wireless, you know what i mean, if i were you i would upgrade that OS to xp, very cheap these days
hope this helps
Posted on Dec 06, 2007
I think it is because 98se is not compatible with broadband or wireless, you know what i mean, if i were you i would upgrade that OS to xp or 2000 .wireless connection is
Posted on Dec 08, 2007
How to do a PPPoE connection?
You have not mentioned OS you are using, i am assuming that you have windows xp or later. Go to properties of my network places and click on create a new connection > Connect to Internet > connect to broadband that requires user name and password .. follow next steps as appears it will install PPPoe protocol and will make a connection also
Jun 26, 2010 | D-Link DFE-530TX+ Fast Ethernet PCI...
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
Can someone please tell me how to connect to the internet so I can send text messages on my psp?
For this you need a broad band connection.Now switch on the psp go to settings go down fully and enter network settings and enter infrastructure mode.There select [New Connection] and you will enter WLAN settings there select scan.While doing this remember to do this switch on the broad band so that the psp will be able track it while scanning.After it finds your WLAN it will show you the SSID,Security and signal strength.Then press 'x' and type the SSID and press the right arrow to continue.Now you mus type the security code if you have one otherwise press none.Then select the address settings to easy or custom and keep going front until you find the sentence 'Press the x button to save settings'.Now you can browse the internet with the connection.But remember to switch on the broad band when you want to browse the internet.
Jan 27, 2010 | Sony PlayStation Portable (PSP) Console
Computer will not reckonise broad band moden
ask you ISP what are the IP address and DNS server address that you need to feed in the properties setting of the TCP/IP setting in the Network Connection wizard in Control Panel
without these the connection will not work
Dec 09, 2009 | Computers & Internet
Internet problem and mbr
use this command
#setup
set up the ip address then restart the
#service network restart
then use internet
Jan 26, 2009 | Computers & Internet
Is acer aspire t180 compatible to smartbro plan 999 internet?
it gives you a connection only that you did not check the box thats say show icon in notification area when connected.go to my network connection in the control panel and click on your connection and select properties. you will see the box below
Dec 19, 2008 | Acer Aspire™ T180 PC Desktop
Dsl faullts
You need to check your DSl line to your Internet Provider so they can properly setup the right configuration for your DSL connection so this problem wont happen again...
Hope that helps..DOn't forget to rate the solution FIXYA thank you...
Oct 05, 2008 | Computers & Internet
Unable to set up internet connection - option greyed out
in order to connect to internet you require a username and password
that user name and password will be given to you durin first time installation if you dont remember the username and password call up your broad band help desk. they will help with the user name and password.
if you are aware of the user name and password ,
you need the configure the internet setup using the user name and password
i ll give the steps to configure the user name and password in windows XP operating system
1 click on "start" button at bottom left of your desktop
2 click on control panel
3 on left hand side of the window click "classical view"
4 then click on the icon network connections
5 there you will find "create new connection"  or "new connection wizard"on the left hand side just   double click on it
6 a new dialog ll appear click next
7 on the next screen select "connect to internet" and click on next
8 on the next screen click on "setup my connection manually" then click on next
9 on the next screen select the option "connect using a user name and password" and click next
10 you will be asked for ISP name "for eg:fill in AT&T"
11 on the next screen you willlbe asked for user name and password , fill in the respective details
for eg: sam @att.net :username
            ******** :password
12 den click finish
you will find an icon in the desk top by now. just double click on that icon and try browsinn
you must be up and runnin ! ! !
Sep 14, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Jan 08, 2008 | 3Com HomeConnect (3C19261) 5x10/100 Mbps...
Microsoft Windows 98 for PC Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
