Question about HP LaserJet 1320 Printer
TRYING TO CONNECT HP LASERJET 1320N TO COMPUTER
Had the Printer running as a network sharing other computers. I now wanted to go solo and disconnected the printer from the network cable and got a USB cable to run from the printer to computer. I went into the HP website to download the installation and have nothing but failures up to now. Keeps on asking me to connect the printer to the computer and put the power on, which it is.
Please could u help me to get this problem sorted out.
Mrb.
Posted on Oct 09, 2008
    President:
  • 4,402 Answers
Unplug the usb from the pc and power down the printer,
then power it back up and plug in to pc see if the computer sees it and then continue the install of the drivers
Posted on Dec 06, 2007
Hp laserjet 3050 - old printer can it be wireless
Hi
Connect the Printer to the Computer which is connected to Wireless Router
Share the Computers and share the Printer (Add Printer - Add network printer - select printer from network)
You will be able to print from anywhere
Regards
Oct 03, 2012 | HP LaserJet 3050 Printer
I am trying to install my HP LaserJet 1320n printer. However, after I select the correct printer port, it asks me to select the software to install from a list. I have Windows XP and the HP LaserJet...
Go here and download the North American full printing solution. This is exactly the same as having the CD and will self install the printer when it runs, just make sure the printer is disconnected when you start the install. Or you can just download the driver and then point the install to the driver file.
Apr 15, 2011 | HP LaserJet 1320n Printer
I have 1320n printer but i cannot print in network plz solve
YOUR PRINTER IS NOT SHARED ON THE NETWORK FIRST GO TO THAT COMPUTER WHERE IT IS INSTALLED AND GO TO "PRINTER AND FAX" OPTION RIGHT CLICK ON 1320N PRINTER THEN SELECT PROPERTY THEN SELECT SHARE OPTION AND CHECK THE OPTION "SHARE THIS PRINTER".
Jan 19, 2011 | HP LaserJet 1320 Printer
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
HP Color Laser Jet printer CM1312nfi: scanner no longer working; when I try to scan, receive error on printer:scanning error, cannot connect. Printer is networked. This error occures only on a networked...
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Jul 22, 2010 | HP LaserJet CM1312 All-In-One Printer
My reconnected printers cannot find my computer to connect through my Verizon FIOS router. The router works fine for my laptop. Printers worked fine a day ago, when they were routed through a second,...
If you are sure the network is working well (computers can see each other but your laptop doesn't see the printer). Got to network places/view workgroup computers. Double click on the computer directly connected to the printer. This will bring up all shared folders and the printer icon (if it is shared). Double click on the printer icon, and it will commence automatic installation on your laptop. Try this.
Sep 13, 2009 | HP LaserJet 1320n Printer
Set up Hp laserjet 1320n & manual
You can get the manual here: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=410622
Jun 24, 2009 | HP LaserJet 2420 Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Network or Share HP LaserJet 2200D Printer
Try this:
1. Go to the computer where the printer is attached or connected. Go to Printer and Faxes under XP, right click on your printer icon, then click on share. On the same computer, click on Start then click on run. Type in cmd then click on OK. On the black window or command prompt, type in ipconfig then press enter. Take note of the IP address.
2. Go to a computer that you want to print on the printer. Click on start then click on run. type in \\IP address of the computer where the printer is attached. For example: On the run box type in \\192.168.1.2 the click on OK. You will see there a window and you can see there the printer that is attached to that computer. Just right click on it then click on Connect.
3. Try to print.
Hope it helps!
Oct 21, 2008 | HP LaserJet 2200D Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
HP LaserJet 1320 Printer Logo
85 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
