Question about Ovens
Electrolux icon dual-fuel range installation problems
Bought this gorgeous range but the oven will not work. The stove works fine and the lights for the oven work but it will not get warm at all. HELP!!
  • 1 more comment
  • mcgpt93 Jan 07, 2008
    same problem as above
  • RoyKar Jun 09, 2008
    I get the same error when I press the reheat button
  • Anonymous Sep 30, 2008
    yep same deal, takes forever to stop the beeping
  • 39 Answers
Its a bad EOC .Electronic Oven Control....You need to replace the board
Posted on May 22, 2009
Hello I am having problem with my Electrolux Icon Stove, everytime i try to turn it on it says F 13 error on the screen, can someone helpp me with this. Thanks You
Posted on Apr 10, 2008
I have not seen a good answer on the Electrolux range top E-15 error. I changed the two boards and verified the wire set with a meter. Does anyone have current solutions for that issue?
I just fixed mine by resetting the stove to factory settings. You do that s by pressing user preferences icon until it gets to the factory settings. Then, press the hi or lo button ( under the numbers) to "yes". Then press start.
Jul 04, 2017 | Electrolux Ovens
Electrolux E36DF76EPS Why does the lock light keep flashing ( note oven works normally )
Hello Thecarsons, thank you for your post!
I understand that the lock light on your Electrolux range keeps flashing and everything else is working properly. This could be a potential problem with your latch or control panel. I would recommend looking over the latch or strike for any visible damage. If you do not see any, I would suggest performing a reset on your range. You can reset your range by disconnecting the power cord or flipping the household circuit off for at least ten minutes. If that does not resolve your problem you may need to have a technician out to your home to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Jun 10, 2015 | Electrolux Ovens
I have an OR90 Dual fuel range oven. My problem is that the main oven the bottom does not heat up? The top is working fine
check both oven elements are working if ok check thermostat probe inside oven isnot close to or touching any of the elements if all os ok then replace thermostat
Feb 27, 2014 | Fisher and Paykel Ovens
My oven will not heat up. When I turn the oven on the lights indicate that the oven is on but it never heats up. The stove works fine.
check the back element to see if it is burnt out ...this is most likley the problem use a flash light to inspect ..to replace the element unplug range..remove racks remove the 2 screws holding the element.. in the back of oven..remove screws on the element to dissconnect the wires ../install new element ..take the back off the range to view all them wires an switches inspect all the wires an switches ..look for burnt wires or broken wires .P/S inspect all wires an connections if bake element looks fine ...good luck ,.let me know if you need more help../joe/
Aug 29, 2010 | Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Ovens Logo
555 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
